What rear end is in my 06 f350 srw? What oil does it take? I had to pull the axles to replace the e brake shoes. Do i just fill it til it comes out the fill plug?
You have to look in your book, it depends on what axle you pickup has in it and yes you fill it until it comes out the plug, if you just pulled the axles and didn't pull the pan off it wouldn't have leaked much and you might have to drive it to get the rear end warm to get the fluid to run back down the tubes for the wheel bearings then check it when its cold.
