Code Scanner Recommendation - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 12-05-2008, 03:19 PM
SteveD's Avatar
SteveD
Offline
Member's Gallery
Can anyone recommend an inexpensive code scanner (under $250.00) to pull codes off my 2000 F250? Thanks!
Reply With Quote Quick reply to this message Go to the top
Old 12-05-2008, 04:15 PM
Pocket
Offline
<-- it's like that
Member's Gallery
Re: Code Scanner Recommendation
If all you want is a code reader, you can search Ebay for a used Superchips programmer. Those usually go for cheap, especially if they are still vin locked. Even a vin locked one can still pull codes. Just make sure you get one that's for the 7.3L.
Other than that, I would recommend Autoenginuity. You'll spend about $350 for it, but it does way more than just a simple code reader.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
  #3
Old 12-05-2008, 05:10 PM
SteveD's Avatar
SteveD
Offline
Member's Gallery
AE's site is confusing. Can you tell me what I would have to order from them to be able to pull codes and store data?
  #4
Old 12-05-2008, 05:42 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Go here for AE. Give Dennis a call, he will tell you everything you need. I believe it may be the same or better price than buying directly from AE.
__________________
  #5
Old 12-05-2008, 06:27 PM
Pocket
Offline
<-- it's like that
Member's Gallery
Follow the link Andy gave you. That's where I bought AE as well. Dennis has top notch customer service, and has a forum section dedicated to answering AE questions.
When you look on his site, you can select various packages. In order to use AE on the Powerstrokes, you need to get AE with the Ford Bundle.
  #6
Old 12-05-2008, 06:36 PM
RedSmokey's Avatar
RedSmokey
Offline
Lovin the Tuna
Member's Gallery
not trying to hijack and sorry for being slightly off, but if you get AE with the ford bundle will it work on any OBDII vehicle just to pull codes or will it ONLY work with fords?
__________________
2001 F250
2000 F250
  #7
Old 12-05-2008, 07:03 PM
Super_Hauler's Avatar
Super_Hauler
Offline
Super Hauler!
Member's Gallery
all obdII ports are the same just get a cheap one if you are hard pressed. it doesnt need to be for powerstroke. Any scanner will work form any auto part store.
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire
99: sclb 6 speed, 4" lift,4" exhaust, EB
99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB
HERS:2001 F-350 ccsb notta stock!
  #8
Old 12-05-2008, 07:11 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Nope.
  #9
Old 12-05-2008, 07:16 PM
Super_Hauler
Offline
Super Hauler!
Member's Gallery
no?? w/e
  #10
Old 12-05-2008, 09:11 PM
Pocket
Offline
<-- it's like that
Member's Gallery
Awwwww, don't pick on the newbie
Human Verification
(View-All Members who have read this thread : 109
02F350, 1highstroke, 2006pelon, 79jasper, 86turbodsl, 97 flatbed f-350, Arisley, baddad, Bamboo, Big K, bigrngyj, big_stroker, Blanco Ford, BoomerL37, Bushwakd, CGMKCM, cntryguy23, countryboymma, countryboyz04, cretedogg, crowz, Cutting-Edge Diesel, D2HP, dblamp, ddelling, Deererainman, DieselBrad, Dieseldumb, draggnash, fatsix, fbilly420, fergus, ferociousfish, firstsgt1978, fordtrucksrule7, gary02psd, Hoofbeat, iceberg, InIraqAgain, JByrdWend, John_DeereGreen, joness, jroller, JSC, Keitho22, kelly mt, kickstand, krankin, kyle43335, Layson, Lazlo, Lee_Bay, LOOSEWHEEL, MagKarl, MATREDGT, mental floss, Metallitera, mike t., mikemax1977, Millerfarms, mjonesjr, monroegt, motocross117, mstepchinski, MSTR-P, mtgrease, MwR, NewDieselOwner, Ohnny101, Onetime12, osumrall, Phiber Optik, PHPDiesel, Pocket, powerstroke95, psdmike, Ranch Hand, randyhoing, Randysrollincoal, Redfish, RedSmokey, rhoads, rick ball, rjhoward32006, rockin jester, rpm-inc, Rus-T, rv7, SteveD, stoneykegonsa, Strictly Diesel, StrokerTurbo7.3, Super_Hauler, tank, TDufur, theSLEEPER, tmackowiak143, TNmatt, TNR, Toronto Turbo.com, trimacwest, txoutlaw, wild67, wildbroncobilly, Wittig412, youngPSD, zabeard
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
