I am posting this late because I have spent the last few hours trying to help a customer out who has purchased alot of parts from us over the last three months to convert his 97 Ford F250 7.3 manual to a 98 Cummins 12V. Long story short, change of events and he needs help getting rid of this stuff fast. He had to get rid of truck and is now staring at a pile of parts. It's late and I am sure we are going to leave some stuff out but it will give you an idea, and all of the parts are new in box and never used.
98 Cummins 12V 98,000 miles
62/80 Phat Shaft
Pulse manifold
191 Delivery valves
Cam Plate #7
Dragon Flow Stage I injectors
Quad Mount Kit
Destroked Plate
Tach P/U and tone wheel
Tach Sensor for kit
Alternator and A/C Brackets, all laser cut or water jetted
Additional Pully for accesory drive
belts necessary for conversion
Vent Tube Delete kit and New Valve Cover with oil fill
Gas Cruise Servo
Throttle pedal
Bench Flowed P7100 Pump
Engine comes with Banks Twin Ram but we don't think it would work in the Conversion.
There is more but it's late and I'm getting a little foggy. Anyways 7800.00 takes the whole package, I have invoices totalling alot more, and I mean alot more. I will double check the list in the morning. We would prefer to sell as a package but we may piece out if we can move everything fairly quickly. Give us a ring with any questions. This package as stated earlier was to Convert a 97 Ford 7.3 to a 98 Cummins. No corners were cut.
Guys,
Where are you guys sending these emails to. It should be aden@gosperformance.com, if that is where they are going I need to check my spam filter. As far as the previous posts go, this is for lack of a better word on hell of a deal. As far as others posting that adding up the parts things dont add up. Well let me do you a quick break down.
Destroked plate 795.00
Phat Shaft 1500.00
Engine 2-2500 yeah if you want to sit around and find one. This one was in the truck running when removed and 90,000 miles. Good luck finding that for 2000.00
Modded P7100 Fuel Plate, Delivery Valves, Govenor kit,Bench Testing and yes it is the 215
500.00
Injectors"These are custom flowed 370 with the correct spray angle" 400.00
Manifold 450.00
Fan Clutch 75.00
Studs 450.00
Gasket Set from Cummins 425.00
Valve Springs 120.00
Quad Mounts and all adaptors more like a kit 1495.00 way less than you can buy it for
misc mandrel piping 225.00
flywheel 75.00
hx down pipe 160.00
Give you an idea on how much something like this cost.
So I will try to find the emails, but please resend if you are still interested, I was on vacation for the last week.
Aden
No that was the parts that went into the pump. Then there is bench time and the cost of the pump itself.
