Ok.. Ive had my truck for about 2 years now and I just got my licens.... Now im wanting to hop it up some.... So far im getting Swamps 250mm Hybird's and a modified H2e. Then we got gauges, TW Chip, fass fuel, hpop, 3in dp and 5in exhaust and head studs... So thats all that I no of that I need.... So if I forgot anything or you have any suggestions please let me no.. The truck has 205k miles so should I do a reabuild sence im going to have tore down? Thanks
Tuning and I would suggest getting some pushrods and valve springs for the piece of mind if you plan to rev it much. The are cheap compared to the items you have listed. I have them and I don't even have the studs yet fwiw.
For valve springs alot of guys including myself use Comp Cams #910-16.
For pushrods I personally have Crowers but there are several options out there.
Also I hope you have or are planning on getting a good clutch, prolly gonna need a South Bend Dual Disc for that kind of power. And your milaege isn't bad, do a compression test to see what the numbers are. If it's been treated well you shouldn't have problems with modding it.
Sweet another IN guy!!!! Welcome to the sight BTW.
