Battery Light on still have 14.5 volts - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 11-16-2008, 08:19 PM
ELKHUNTER's Avatar
ELKHUNTER
Offline
Member's Gallery
Anyone know how the battery light is triggered, I have the light on the dash but voltage is 14.5 at the batteries with the engine running.
__________________
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
Reply With Quote Quick reply to this message Go to the top
Old 11-16-2008, 09:24 PM
matthewd11's Avatar
matthewd11
Offline
Member's Gallery
Re: Battery Light on still have 14.5 volts
There is a single wire circuit, it is a single pin connector on the alternator. The connector on the alternator or the connector on the wire itself can be fubar. Just because it is putting out 14.5 V doesnt mean it is putting out the right amperage, either. Wiggle that single pin wire and see if the light goes on and off. If that doesnt work, have the alternator load tested and diodes checked.
Just curious, does that meter you have read AC voltage? If so, measure the AC ripple at the battery. It should be less than 0.1 V.
__________________
  #3
Old 11-16-2008, 11:26 PM
ELKHUNTER's Avatar
ELKHUNTER
Offline
Member's Gallery
Only one 2 pin connector on the alternator, and on AC I read 0.3 to 0.1. I was curious if the PCM sets the light and how it determines to do so since there wasn't a single indicator wire like I am used too. Are one of the wires on the 2 pin plug for that, I thought one was a ground and one positive.
Thanks for the help.
  #4
Old 11-17-2008, 04:09 PM
PHPDiesel's Avatar
PHPDiesel
Offline
Butt-Head
Member's Gallery
Like Matthew said....
It's a single wire from the alternator (in the 2-wire plastic connector) that goes DIRECTLY to the back of the cluster.
With the engine running, disconnect the 2-wire connector (please be careful). If the battery indicator goes out, it's the regulator grounding the indicator circuit....
See this thread...I posted some pictures of the charging circuit:
http://www.ford-trucks.com/forums/78...-randomly.html
__________________
Cody
  #5
Old 11-17-2008, 06:00 PM
ELKHUNTER's Avatar
ELKHUNTER
Offline
Member's Gallery
Thanks
  #6
Old 11-18-2008, 03:28 AM
CSIPSD
Offline
Banned
Member's Gallery
There is a fuse that can blow and make the Batt light stay on. I cant recall which one it is now but mine did it.
  #7
Old 11-18-2008, 05:07 PM
PHPDiesel's Avatar
PHPDiesel
Offline
Butt-Head
Member's Gallery
Fuse #6 in the underhood fuse block runs the "exciter" circuit in the regulator. Check it. 10A
  #8
Old 11-20-2008, 03:28 PM
txpsdcrwchf's Avatar
txpsdcrwchf
Offline
Member's Gallery
Send a message via Yahoo to txpsdcrwchf
man i bet the alternator just isnt putting out the correct amperage... does the light stay on all the time or is it intermittent? mine would always come on when i first started and go off till i started driving...
and i belive this is because the GP circuit was taking up the amperage and the batteries would then fall below the 12v. or whatever sets off the light. the alternator would put out enough power to run the truck and keep the batteries charging but not enough to actually charge them.
Also when i towed a trailer with brakes when i hit the brakes the draw from the trailer would almost kill my truck. so just because you have 14.5 at idle under no load doesnt mean the alternator is good.
mine gave 14.5 every time i checked it light on or off. couldnt really check it under load...
so id get the alternator load tested and id bet youre more than likely gonna have to replace it. just be happy its giving you a warning and not just going out randomly when youre in the middle of a 1200 mile roadtrip with the kids in the back and ma in the right seat.
__________________
Jeff
HIS: EARLY '99 F250 SD 4x4 Off Road, 7.3L PSD 6 SPD SuperCab Short Bed
DP Tuned (F5) NS, S, 40T, 80E,
HPx Line-DIY Tymar-Fuel System(on Return)
HERS: '99 DODGE Ram 2500 4x4 5.9l I6 Cummins 6SPD QuadCab Shortbed
Edge ez 20, 40, 60:
  #9
Old 11-21-2008, 08:31 PM
casper7.3's Avatar
casper7.3
Offline
Member's Gallery
unpluging the connector will make the light come on you should have at least the batt voltage to both the small wires... with the engine running 13-15 volts i think there are also two ...5a fuses there they are for dual alts but are still wired there for some odd reason had one 5a through me for a loop.
__________________
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
  #10
Old 12-29-2011, 02:42 PM
jwchurch
Offline
Member's Gallery
So I changed out my glow plugs, valve cover harnesses too. After putting it all back together, Battery light is on? Read your post, unplugged pigtail, light went out. Wire kinda loose on plug so bought a new one. Same problem, battery light still on. #6 fuse replaced, batteries and alt check ok? Alt new last year.
What did I leave unplugged?
Need help, THANKS!
Jeff 99 F250 7.3 SD
Human Verification
(View-All Members who have read this thread : 235
02psd, 02silverbullet, 03threefiftyz, 06 f250 man, 06VT365, 1995f350, 1997.3f350, 1999SuperDutyStroke, 331stroker, 7.3 Powered, 7.3psd1999, 91turbogsx, 96centurion, 97slow, 99coalroller, Aaron S, abbottfarms, ackdog, AJF, ajfetterman, Aminator, Arisley, biallc, Big K, BigRed97, BKex, blackedoutsd, Blowby, Boomer, Bradbilt, BROCKDIESELDUDE, buffaloslobber, Bugman, Bushwakd, cadwell08, calebgriffin31, Calico5, Capester, casper7.3, Caster, cat45, CATdiezel, Ccoff864, CGMKCM, Chop357, chopper, Chris659, Clatterindiesel, clydesdale, clyne, COFG-28, colbev57, colekym, CooterBrown, countryboyz04, crowz, CSIPSD, cvdenson, daddyed73, davet808, dbd181, dblamp, DcMoore999, deerhuntr, dentexpowerstroke, Dfirmin11, DieselBrad, diesellee, Diesel_Dust, DIRTBIKEZ, ditch_dawg, Diverhardhat, Doodah, dorton14, dorton413, doubledoor, Dude! Sweet!, Dustin F2504x4, dzlstroker, e444, ELKHUNTER, eric96ford, f-150_xl, fabricationfool, Fever, Firedogbme, Fl Stroker, Ford3544, ford7.3sd, fords4life, ford_trck, Fragoso87, Gary T 51, godofdew11, Gotti2k7, Gregch, gunnellett, Harley Strokin', Hawkshaw, Holleran, huck2080, Imjosh, INFOCUSHAULER, ironworker25, jaglmm, jake2far, Jamie5714, jamisgood, jawsfx4, Jbgabriel, jeromejcp, JHill, Jingoist, JMC1210, jmkeck, Johnboy3, jonstangnelson, Jorobe33, JSchuricht, jsquyres2004, jwchurch, KeninAZ, kilowatt, kingranch1, koky131, krankin, KrayzKajun, La7.3, Lawn Jockey, leoneo01, LiftedLariat, Lone_Domino, LongGun_LeRoy, LOOSEWHEEL, Madisdaddy0505, Marauder, martins96, mason93, Matt-F350, matthewd11, mattr66, Mayday, mazdaparts, mbechert, mbg75, mck7916, middlemanjw, mino_h, mmm635, mostlystock, MTNSTROKE, mustang_gt_350, nchappy, neverkickn, newmexicocrawler, noe2big, Nomapride, NorCalDiesel, NotMatt, NV Stroker, OFarrell, old man dave, ole_blu, oshmago, Pastordan, PDEMICH, PHPDiesel, PSDfan99, PSDOWNER, psims20, PWRstroke_smoke, pz2435, QtrHorse, razorscs, red95psd, Redfish, redracer62, Riley250, rndllquinn, robr1970, rockmanmaine, Roush4_6, rpm-inc, Russo2, scheidt27, schemi, shane431, ShiftyCapone, sho669, shotgunts, sick97psd1, Sigster, SLO DZL, slowleak, smokyred, sozo, sparksmx450, speeddemon31176, squeak12, stick6, Stites02psd, Strictly Diesel, stroked, StrokerTurbo7.3, super73, Supercoupe, SuperStroker10, svorob, The Struggler, Tinscout, Torque37, tripleblk03, twerksomtin, txpsdcrwchf, Tylerjm7.3, UNCOOL, urbandiesel, urbanwheeler, usmcpsd, victorcharlie, vsullivan, wadeclinton, wildsteelhed@gmail.com, wmc, wooner, XR7, yobuda, yzdude250f, Zmann, ZMONSTER
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
