Thanks Zmann, do you run that tranny pan on your truck?
I drive. 2010 cc sb.
The measurement I'm looking for is from where the diff cover bolts on all the to where the farthest point at which the hytech sticks out..? I guess you could call it the depth.
The reason I need that measurement is cause I have dual stabilizers in front of it and need to know if it will clear!
Hope that makes sense, I really like the look of them. My truck is lifted 8" so all you see is the under carriage. Help clean it up a bit!
Thanks Zmann, will look into that pan!
Your truck is clean! Winters are hard on rigs up this way.. -40c 3-4 feet off snow. Salted roads.. It's a full time job looking after joints. Nuts,bolts. Seals..
ahh with salt I may go with a Hytech trans pan instead of the Derale
