203 degree Thermostat - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 7.3L Power Stroke - Aftermarket & Performance
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 09-18-2008, 03:45 AM
lords88's Avatar
lords88
Offline
Praying for BOOST!
Member's Gallery
I recently had a leak coming from my water pump where the housing seals to the thermostat, so I decided to take it apart and see what the problem was. Long story made short I ended up cracking my water pump due to a froze bolt. Since I have to replace the pump now I was wondering. Is the 203 degree thermostat worth putting on the truck, and a new billet housing?
__________________
2002 F250 super cab w/long bed :thumb:rapid flow intake, zoodad mod, wicked wheel, bellowed uppipes, Custom Wildman Tunes! 4'' exhaust, 5'' rolled chrome tip, banks transcommand, dual trans coolers, cooling mist inject, wheels, tires, tinted windows, and all the chrome accessories I can stack on it! :nod:
Reply With Quote Quick reply to this message Go to the top
Old 09-18-2008, 03:49 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Offline
Subject Matter Expert
Member's Gallery
Re: 203 degree Thermostat
You dont need it, and it doesnt really make a noticeable difference. It's not easily seen either. I guess you call it one of those mods that just sounds cool. Billet this, billet that... In theory it works, and may help engine efficiency a smidgen.
__________________
Stock
  #3
Old 09-18-2008, 03:52 AM
lords88's Avatar
lords88
Offline
Praying for BOOST!
Member's Gallery
Well I read that if I removed my thermostat housing which I have to to replace my water pump, that it won't seal. Is this true or is this them trying to sell a product?
  #4
Old 09-18-2008, 03:59 AM
69W900A's Avatar
69W900A
Offline
69W900A
Member's Gallery
Yes, the billet housing is much nicer than the OEM sheetmetal one. However the OEM replacement is like 15.00 at the dealer. The 203* will help trucks that run unloaded most of the time, it will do nothing for a loaded truck and may actually cause the fan to run more often slightly. It just depends on how you drive and what you use your truck for.
__________________
TAG II, Exhaust Air Guide, K&N FIPK, Hood insulation delete, foil delete, SX and A1000 pumps, door dinger delete, COMPOUND trans coolers and a Banks Stinger+++ with the Banks TransCommand and Chrome curb Feelers.
248.9HP 4ft/lbs @ 3,400 RPM (don't forget to divide by 1,002 and carry the 5).
Nothing worse than a good idea that doesn't work.
  #5
Old 09-18-2008, 04:15 AM
lords88's Avatar
lords88
Offline
Praying for BOOST!
Member's Gallery
so I am guessing the dealer housing and a gasket should do the job huh. No need for me to spend money on anything that wont really help me out that much
  #6
Old 09-18-2008, 05:10 AM
snakyjake
Offline
Member's Gallery
I'd like to verify too. I just got the billet housing and thermostat. A o-ring came with the thermostat. No gasket came with the billet. Am I supposed to get a new gasket for the billet housing?
Thanks,
Jake
  #7
Old 09-18-2008, 06:55 AM
kupaa's Avatar
kupaa
Offline
Member's Gallery
I used some blue rtv because it leak with just the o-ring.BTW the 203 stat did nothing for me,couldent tell the difference from stock.
__________________
02 F-250 SC SB 4X4
AUTOMETER COBALT EGT BOOST TRANS
4'' SILVERLINE TURBO-BACK STRAIGHT PIPE
6637 INTAKE
HP CROSSOVER LINE
DP TUNER LIVED TUNED BY JODY
JOHN WOOD STREET PERFORMANCE TRANS
CASSERLY 200CC 80% HYBRIDS
TERMINATOR MODDED HPOP
ITP REGULATED RETURN
GARRETT GTP38R
ITP OVERBOOST ANNIHILATOR
468HP 970TQ
CHRIS
  #8
Old 09-18-2008, 08:01 AM
kainers's Avatar
kainers
Offline
Starting Over
Member's Gallery
same here 203 had no noticed difference on the performance of jizzy.Heater is seriously hot in the winter though.
  #9
Old 09-19-2008, 04:59 AM
rebelchevy02's Avatar
rebelchevy02
Offline
Member's Gallery
I didnt notice any difference on day to day driving with the 203, however, when towing, I notice the engine fan comes on alot more then it used to. Makes me want to pull it back out, and go back to the stocker. But it doesnt leak now, and it has final charge antifreeze in it. So Id rather not mess with it, unless I get really, really bored.
__________________
Detroit locker and go fast parts.
  #10
Old 09-19-2008, 05:33 AM
snakyjake
Offline
Member's Gallery
I believe International puts the 203ºF thermostat in the T444E. I don't know if the cooling system is any different between Ford and International.
But I have heard diesel mechanics say that a hotter diesel engine is better. Something about burning more of the soot out and keeping the engine cleaner. Maybe it's kinda like cooking the crud off the BBQ grill, or using a self-cleaning oven. Or maybe it was more about a hotter engine that makes it more efficient at creating a better combustion.
  #11
Old 09-19-2008, 02:02 PM
Haul_n_horses2's Avatar
Haul_n_horses2
Offline
Member's Gallery
Originally Posted by snakyjake View Post
I believe International puts the 203F thermostat in the T444E. I don't know if the cooling system is any different between Ford and International.
If IH put them in then we would be able to order it from IH rather than Bob Riley. This is not the case. The waterpump/cooling system in PowerStrokes never to my knowledge used a 203 t-stat. The temperature was decreased to reduce NOX emissions. There is supposed to be a modest improvement in combustion efficiency with higher temperature. I have never been able to measure any difference in MPG with the 203 t-stat. The older t-stat from IH that was 203 was not designed for use with the waterpumps on our vehicles.
__________________
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
  #12
Old 09-19-2008, 02:12 PM
casper7.3's Avatar
casper7.3
Offline
Member's Gallery
the ford replacement t-stat o-ring has leaked on me on several different trucks. now i use the motorcraft t-stat w/ the napa o-ring with no nedd to use rtv, btw if you have to ever replace the t-stat again rtv is a mess to clean
  #13
Old 09-19-2008, 02:38 PM
Torque37
Offline
Member's Gallery
I switched back to the Ford thermostat, after not being able to stop the leak on the 203*. If you look at the 203*, it is actually thinner and smaller in diameter than the Ford. The smaller diameter causes the o-ring sit crooked on the 203* causing a sealant problem. The flange is actually thinner causing o-ring to sit further down inside of the waterpump.
__________________
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
  #14
Old 09-19-2008, 03:14 PM
lords88's Avatar
lords88
Offline
Praying for BOOST!
Member's Gallery
Will the Napa o ring seal with the stock ford thermostat?
  #15
Old 09-19-2008, 04:23 PM
clydesdale
Offline
Member's Gallery
I like the billet housing. It will survive several t-stat changes. I think I ended up with a .5mpg bump from the stat, but that is debateable. But I would do the billet housing for sure. My housing did not have many miles and it was corroded.
__________________
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
  #16
Old 09-19-2008, 04:33 PM
casper7.3's Avatar
casper7.3
Offline
Member's Gallery
yes the napa seems a little larger than fords gasket. and the new replacement motorcraft t-stat's flange is thinner than the factory one. thats just something that i've run into.
  #17
Old 09-19-2008, 04:59 PM
mitchrock1
Offline
Member's Gallery
I'm using the billet housing with the 203 stat with no leaks. I reused the original housing when I replaced the stat but couldn't get it to quit leaking. The billet housing cured the leak issue.
__________________
1999.5 F250 2wd SC 6spd PSD
DP Tuner, H2E, AFE, AirDog, Reg Ret, ETC...
  #18
Old 09-19-2008, 11:42 PM
southmike's Avatar
southmike
Offline
Village Idiot
Member's Gallery
lol
i use a 203 tstat with the same ol rusty almost bent stamped POS
original housing on my ride ...no leaks , down side i have seen .
international runs a 203 in some models but the stem is either longer or shorter then what our trucks use...I think.
__________________
  #19
Old 09-20-2008, 12:31 AM
Haul_n_horses2
Offline
Member's Gallery
Originally Posted by southmike View Post
linternational runs a 203 in some models but the stem is either longer or shorter then what our trucks use...I think.
shorter. That is why I said you cannot use the IH version.
  #20
Old 09-20-2008, 09:32 AM
Torque37
Offline
Member's Gallery
I am also using the billet housing with no leaks, far better than the OEM housing.
  #21
Old 09-20-2008, 10:50 PM
SD26's Avatar
SD26
Offline
Member's Gallery
I've had the 203* stat in two Power Strokes. Noticed it more in the E350 where I could hear and feel the engine run smoother below 2000RPM's...above that, I think they all get pretty smooth. Was better for mileage in the E350 too. Ran it almost exclusively pulling an 18ft enclosed auto hauler.
In the Excursion, I haven't noticed any dramatic differences.
__________________
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
  #22
Old 09-21-2008, 01:05 AM
JohnT
Offline
Member's Gallery
Send a message via AIM to JohnT
Run the stocker, had a 203* and I don't think I noticed a difference with it.
__________________
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
  #23
Old 09-22-2008, 01:35 PM
tch.280
Offline
Member's Gallery
The 94.5 to 95 Powerstroke had the 203 degree short Stat and water pump.
96 and up use a different waterpump and Stat. After 97 IH no longer sold the 203 degree short stat either, could only get it "aftermarket"
__________________
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
  #24
Old 09-22-2008, 04:08 PM
snakyjake
Offline
Member's Gallery
From my reading, International put a 203F thermostat in the T444E, and also the earlier engines. You are right that they did not put the same exact thermostat into our engines. They differ in stem length. The stem length is different because of the slight differences in the cooling system (ie. coolant bypass valve).
Between my reading and what diesel mechanics have told me (no scientific proof here, so for what it's worth...), International created the 203F thermostat for a better operating engine. Ford changed to the 192/195F for the purpose of reducing emissions.
The temperature difference between 195 and 203 is probably not significant enough to matter to the intake, intercooler, exhaust, or EGT.
For me, I'd rather go with what International does with the engine. They are the ones that designed the engine, fully tested the engine, have the most experience, know diesels, and did what's right for the engine, rather than for the EPA or other bureaucracies that Ford must deal with.
Jake
  #25
Old 09-23-2008, 12:29 AM
lords88's Avatar
lords88
Offline
Praying for BOOST!
Member's Gallery
Has anybody else had problems getting the bolts out of the water pump where the fan bolts on? I have two bolts that wont budge? Any advice? I can't take the water pump out without removing the fan first, correct?
  #26
Old 09-23-2008, 12:36 AM
Dieselfever's Avatar
Dieselfever
Offline
2010 BOB Points Runner up
Member's Gallery
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
10 degrees isn't enough to notice as far as heater temp or the gauge will show, but the extra heat will made a more efficient engine at operating temp. More complete burn that is, but a more complete burn will make more NOx emmissions verses Unburnt hydrocarbons or Particulate Matter.
I know that the man with the highest MPG PowerStroke uses a 203 degree themostat in his truck.
As for the leaking, it's a PITA to get these freaking water pumps to keep from leaking! Even a brand new, non-reman with the lower pipe already installed I've had them leak, multiple times. Same with the crappy thermostat housing that we've had to bend the corners upward to apply more pressure to the seal.
-Michael
__________________
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
  #27
Old 09-23-2008, 01:09 AM
JohnT
Offline
Member's Gallery
Are you trying to remove the fan without removing it from the water pump itself? I think I understand what you are saying, there are 4 bolts that face towards the front of the truck, and four bolts that face towards the rear. You don't need to touch those until the fan/fan clutch assembly is off the truck.
To remove the water pump, there is only one big nut to take off. Its the one attached to the fan clutch and into the water pump. You can see it, its a pretty big nut right in the middle of the four bolts on both side. Its on a shaft. After that the fan and clutch come off as an assembly. Then you can proceed to remove the pulley off the water pump. You can't remove the pulley before your remove the fan and clutch which come off as one piece.
  #28
Old 09-23-2008, 01:45 AM
69W900A's Avatar
69W900A
Offline
69W900A
Member's Gallery
All but two of the 444E's we used to have in the fleet came with very low thermostats right from Navistar. They were like 147* or something along those lines.
The only time the thermostat opening temp is gonna affect much is under light load conditions. If you are using your truck you will build heat and the differences between the thermostats will not make one bit of difference. If you are driving 2 miles to the 7-11 in an unloaded truck in the middle of winter, then yes a 203*stat will help.
  #29
Old 09-23-2008, 02:49 PM
lords88's Avatar
lords88
Offline
Praying for BOOST!
Member's Gallery
So how do I keep the shaft from turning in order to remove that one big nut?
  #30
Old 09-23-2008, 03:52 PM
JohnT
Offline
Member's Gallery
You will either need to hold the pulley with some sort of gadget you make, or you can get the Ford Pulley Removal tools from Autozone, which allows you to hold the pulley while removing the fan/clutch.
  #31
Old 09-23-2008, 04:01 PM
snakyjake
Offline
Member's Gallery
Please start a new post. Some of us are trying to follow the 203 thermostat discussion and have subscribed to updated posts regarding the topic/thread subject.
Thanks.
  #32
Old 09-25-2008, 04:54 PM
southmike's Avatar
southmike
Offline
Village Idiot
Member's Gallery
Jake
well there you have it .
I haven't seen to many emission reducing designs give better milage or power.
I haven't seen any great jump in performace milage etc.. mabey an eak under 1mpg that only the lie-o meter (overhead inaccurate display ) can detect.
but no loss of performance either.
  #33
Old 09-25-2008, 06:21 PM
SD26's Avatar
SD26
Offline
Member's Gallery
Extra heat can increase mileage and reduce HC and CO, but NOx is the one that gets a lot of environmental programs all up in arms. And that's where the hotter T-stats have caused problems in diesel and gas engines on the regulation side.
  #34
Old 09-25-2008, 07:54 PM
snakyjake
Offline
Member's Gallery
Ironically, biodiesel raises NOx too.
  #35
Old 09-25-2008, 08:14 PM
casper7.3's Avatar
casper7.3
Offline
Member's Gallery
:no kidding:
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 276
00PSD1, 02EXCURSION, 02F350, 03miracle60, 06_WhiteBull, 1snotrocket, 2000Censtroker, 250truckguy, 310K_Stroker, 444-4D, 69W900A, 6liternole, 7.3 King Ranch, 7.3EX, 7.3freak, 97stroker5, 99 7.3, 99F250Smitty, 99redf350, 99STROKINSMOKIN, Aaron S, ackdog, aklim, AMB, Arisley, atlantis, badluck_early99, bazdog1, benboo, BeringSeaFisher, bert, big bad stroker, Big-Stroke, bigd4me2, bigfastford, bigredstroke, Bjesse, BlackPearl03, blacksport03, Bleedgreen, Blowby, BMac, bobbydb1, bobzilla1959, Boomer, boondocker13, brandon_oma#692, Bushwakd, Caballo Diablo, calebgriffin31, CAROLINAKID, caseih7010, casper7.3, cemeyer, Charles, charlie99, Chuck B., Clarkestrong, clayc_989, clux, clydesdale, Cmonster, CooterBrown, cota, cowboy_dan, craigerwilding, Craneman, crowz, cvdenson, Dansk, dblamp, Deputydog, Dieselboy, DieselBrad, Dieselfever, Dieselgeek, dinikin, ditch_dawg, Diverhardhat, dixieland-diesels, dofalt09, drtydzel, dstruble, dunesday, dzljon, F-350, f250towrig, f350mike, Fantom, fastbirds, fbilly420, Fddriver2, Ferd Killa, Firedogbme, fyrehose, Garbage_Mechanic, Gibrid4x4, glamis_dave, gman77, grecoface, greenbeast, greenlion, Greg373, Gregch, Griz, gtx, guzzle, HandyMan, Haul_n_horses2, hawkeye, hawk_crew_dog, Haztanker, hcwt, HotRodTractor, hunter scar, IH_deere_slayer, Imjosh, indyF-350psd, jcmagone, jeromejcp, Jimbo*, joebob3093, joediesle, Joedog, joedown, John-Boy, Johnny77Mutt, JohnQBuilders, jones17, JSlack, JuststrokeIT, KAC1023, kainers, kb1, kickstand, kip4234, klipz, KMurakami, kolb, krankin, kupaa, kyle@DI, Layson, Lee, Longdrive, lords88, lownslow, makaveli200369, Martin #6, Matt-F350, mattr66, mattrac, mavricktoo, MAXPWR, mbruce, metalnova, MidTennPSD, Miffsudd, Mikes7.3, mikes95powerstroke, milehighstroker, MILFORD, missmanj, mitchrock1, mnstroker, Modman, motoxlrg, Mr. Bob, mrprincedog, nchappy, nixter, NjCj, NyCowboy87, Oilfield_Digger, opie977.3, Orezona, outlaw5.0, PAbowhunter, paine, powerstrokeG38R, PowerstrokeJunkie, PSD POWER007, psdexcursion, Ramblin'_Man, raptor, rebelchevy02, red95psd, Redfish, res0wc18, Reubine, rich in co, Rob02F350, Rockcrusher, Rockrunner86, Rodknocker, Rogue1970, Ron's power stroke, rpm-inc, rusty9cab, saint_nick3, samdust, sandnut, Sapps, savvy1, scott440, SD01WD, SD26, sdfd504, Shadetree, Shaw, shoemaker88, silverslug, Skooter_Built, skylinedan, sled hauler, slowleak, smokindiesel2, smokinndstrokin, smorris, snakyjake, southmike, speediseverything, srq, stroked350, strokin7_3, SuperdutyBrian, superih, superm, suprdzlduty, SWVa, Tampa450, tank23, TARM, tch.280, thagoob02, TheDirt, theSLEEPER, TimberPro, tjbeggs, tjmarino18, tkdbf350, Tom S, TomzToyz2, TooManyToys, Torque37, trackspeeder, treyloco, trolling2, truckcap22, two-rocks, TXstroker01, Tygen1, UNBROKEN, UNCOOL, UNLIMITED_DIESEL, vintageracer, Willy, wjamesm, wooner, wyoming9, xray88, yobuda, zankof, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
