No you will not be able to read fuel pressure with a scan gauge. The scan gauge only reads factory sensors. The CTS does have the ability to read fuel pressure BUT that's with an added sensor that YOU install
Thanks guys, so will the icp reading tell you if you have any leaks in the high pressure system? It will tell you how long it take to get to 500 psi to fire the injectors?
ICP- high pressure oil system
IPR- high pressure regulator position
The ScangaugeII will monitor everything the trucks on board computer does.
It is also a code reader for the truck and any OBDII vehicle. It is the best monitor for the money there is no doubt about that.
