I have a 6" coil lift on the truck and was wondering if i could put the leveling coil spacers in with them? I will also be lifting the rear to match. Thanks.
Do you got the 4 link? If you do just adjust the caster. Then you would have to recenter the axle. The track bar bracket you got maybe ok but i say put the spacer on and see
