Hey guys im looking fo a lift kit fom my Excursion lil bit on a budget of $1000 i found one at Zone for 900 fo a 6" is this the best im goin to get? is it any good?
What year is your excursion? It says it fits 00-05 but in 05 they changed to coil over suspension..that kit looks like its for a leaf spring front end.
All '05 Excursions came with leaf spring front suspensions but the '05 pickups had the coil spring suspensions. So if your using a kit that fits the pickups on your Ex it needs to be one for an '04 pickup. If it was me I'd give Cary at CT Performance Inc. a call.
It is a tight fit and i had to do some trimming on the lower valence and pull back the rear of the front inner fender. I ended up doing a v code up front with a mini spring pack. In the rear i did a modded b code. All in all i got most the stuff from cary but i did spend about $1,800 but it rides very nice and lifts my 8 1/2' v plow just fine.
