just wondering what lift and/or rim dimensions it would take to get 37's to fit under my 4" lift. Currently I have stock rims and 315/70/16 tires. Its a CCSB.
Thanks, here's a couple pictures for reference.
sorry it took so long, forgot i had this thread..no for the avatar pic, mostly street with the very limited off roading...i was looking at 37" toyo mt (if that matters)...i live in WA with lots of rain and snowy winters
I have a 2009 with 37 Toyos on factory 20s with 2.5" level kit. I don't know for sure what it would take but I do know the fender wells are smaller on your body style. If you can get them under there it's probably going to have to be on a wheel with similar dimensions as your stock wheels. I had a 2004(leaf springs in front) with 38x14x24s -44 offset wheels with 6" lift. They scrubbed pretty bad, had to do major trimming on the inner fender plastic, lower valance, and metal where the bottom of the fender bolts up at. That was scrubbing with no flex. That truck never saw anything but pavement. Not sure how much help this is but maybe give you a little perspective.
There is another current thread going on 99-04s with people running 37s on leveling kit only. Not sure of backspacing on there wheels but definitely looks like you should be fine with a 4" kit
yep mine has a 4 inch lift and I run 37 inch in the summer that are 12.50 wide on wheels with 4.5 backspacing and they dont rub even in full tilt. Now if I put the other set I have on the truck they will rub at slight tilt even but those rims are 12 wide with a 5 inch dish on the outside and the tires are 37x14.50. If you want to just put a 4 inch lift on make sure your wheels are close to the 4.5 or stock backspace cause the farther out you come the more likely they will rub. Plus the deeper the dish the more load on the not so forgiving wheel bearings also......
Thanks everyone for the responses...i have stock rims right now and dont plan on replacing them anytime soon, so with the responses looks like i'll be getting 37's for my next tires instead of 35's.
I've got a 2003 7.3 with a 2.5 inch block kit under the front end and i'm running 37 bfg on 18in moto metals.. Yes do have a small amount of rubbing but only at about half turn
I've got a 2001 with a 4" lift and 37s. The first set of wheels I ran had about 4.5" of backspace with surplus humvee tires. On the front they rubbed the springs and hit the hit the fenders when turning hard and hitting things like speed bumps, gutters and pot holes. The rears hit both the front and back of the wheel opening while driving in places you shouldn't be driving a truck that size. After I had body damage on all 4 corners and torn up inner front fenders from the tires, I put cut-outs on and got a set of these wheels (http://www.trailworthyfab.com/images/D/d-17520-14.jpg) with a 3.5" backspace and a set of 37" retreads from Treadwright studded for winter. Now nothing rubs, I can air down as much as I want and never blow a bead and I can change a tire on the wheel with only a wrench. The inserts are a real pain to get in and out of the tires, but you don't need them if you don't care about the beadlock part.
So, ya. 2004, CCSB, mostly stock, 2.5" mini spring pack up front for a leveling kit. I've run 37/12.5/17 for years on a couple different wheels but, very close to stock backspacing. Almost no rubbing anywhere but on the front springs.
I've definitely taken thus truck through places no superduty has any business going. Full articulation, to the point the truck two tires off the ground, front & rear, opposite corners. Betty little rubbing except at full lock & then only at the springs.
Also, had it off the ground a few times (mostly on purpose) & no problems there.
awesome, thanks!
now just hard finding a 37x12.5x16
