With such a low lift height it was the best I could come up with other than buying or duplicating the OUO mount. I should have also cut the stud off of the trac bar ball joint. The mounting bolt for the rod end of the ram ended up clearancing the stud by about a half mm.
I also never got a chance to cycle the suspension to full compression to find out if the ram was going to hit the frame section that crosses under the engine. So far its hit the bump stops and the ram is ok.
