i am getting close to finishing my suspension and will be putting the adj track bar and drop on. i didnt take great measurements before i took it apart. do i put the truck on the ground with the track bar off turn the tires and install the track bar where it sits?
Everything sounds good except for the part where you say turn the tires. If you turn the tires, the steering is going to pull the frame to one side in relation to the axle.
Set it on the ground and install the bar. If the axle apears to be centered under the truck left to right then your good. If not adjust it so it is.
