Hey guys I have a 2004 F 350 with a leveling kit. I am taking the leveling kit off to have a stock height front. I'm wondering if I can swap out the rear blocks with a 2 inch 250 block without any problems ? Another question is will the rear sit lower than the front ? I am newer to the forum just asking for a little help I'm stumped. Thanks
There shouldnt be any problem with swapping in a shorter block other than the possibility of needing shorter U bolts. If the springs are in good shape then the truck will probably sit like other 250s and sit slightly lower in the front.
