| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
DTC p1280 and 1284 help!!!
I have a 2003 F250 with the 7.3 powerstroke. I had some stumbling and the CEL light came on. I ordered the OBDscan software and pulled codes and got p1280 p0000 p0000 during the KOEO test. During the KOER test it displays a p1284 P0000. I know they are related to the ICP sensor. I have checked continuity between the sensor connectors and the pcm plug and all three wires showed no break in continuity. I did a voltage check on the sensor connector on the harness from this linkhttp://www.thedieselstop.com/faq/949.../ecsd/icp.php3
and everything checked out is there anyway to check the sensor itself? Any help would be greatly appreciated!!! |
| Sponsored Links | |
Advertisement |
#2
Re: DTC p1280 and 1284 help!!!
P1280 ICP Circuit Out of Range Low
P1284 ICP failure. I would say, replace your IPR and should be good to go! You can also disconnect the ICP sensor, which will throw the PCM into default. If the truck runs better replace that sensor as well. Does your ICP sensor have any oil leaking from it? |
#3
__________________
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed. CCV Mod knn intake banks exhaust banks power elbo banks turbo housing big head waste gate-disconnected Tuning by Gearhead Automotive Performance 4 gauge pod with DiPricol pyro, boost, trans temp, HPOP http://www.dieselpowerproducts.com/ |
#4
I have disconnected the ICP sensor and the truck does not run any differently. The connector on the ICP has no oil in it and I cleaned the contacts with electrical cleaner with no change in performance. Also the truck died on me the other day and fired right back up. Is this related to the IPR?
#5
Check to make sure that the nut on the IPR is tight. I had mine come loose once and it acted just as you describe.
If it is tight your IPR has problems and you might as well get a new one. You can try to take it apart and clean it but that doesn't always fix them.
__________________
Eric 96 F-350 CC Dually 300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
![]() 6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL |
#6
Thanks, I'll try and clean it and see what happens. Do you know if a bad IPR will cause the truck to stall??
#7
Yes, the IPR can cause the truck to stall. |
#8
__________________
Rick.... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families www.fordtransmissioncure.com Special thanks to RacerX USA www.racerxpower.com |
#10
well, I removed the IPR and dissassembled it and cleaned it with no change. I wiggled the connector to the IPR and the truck would not die. I was wondering with the DTC 1284 it identifies an ICP circuit failure during the KOER. Wouldn't those to codes narrow it down to the ICP sensor or connector? Also, will the ICP cause the truck to die?
#11
No. Bad sensor or connection will trip a code and it will run in default(780psi at idle and 2475psi at WOT, plus or minus a couple points). I would replace the IPR with a new one and maybe the ICP sensor as well. Or, go find a friend with a PSD and barrow his ICP sensor?
(View-All)
Members who have read this thread : 75
| 1snotrocket, 2000XLifted, aklim, Andy's 250, Arisley, BigBlackSooter00, bigwheel, brickhead, Bruinzfan, cnsmith, Craig@MPD, dblamp, diesel slacker, Dieselfever, Dirtyryder, ditch_dawg, ELKHUNTER, fastbarryracing, ford7.3diesel, geargrabbin97, Gobstopper909, greenbeast, Haul_n_horses2, hendershot, iaff284, injected79, irontx25, JD3020, JerseyJim, JHill, JohnDeere9610, John_DeereGreen, JuststrokeIT, lords88, MagKarl, matthewd11, mattrac, maverick5.0, mnstroker, muddy_one, mx929racer, mytmousef350, NorCal997.3, OUTLAW101, phoneman, PHPDiesel, powerstrokin7.3, PSD POWER007, PSDfan99, racehauler, ridiculously_necessary, Riley250, rjm0027, Rogue1970, Rustler, SeeYa, semomotorsports, shawnberrier, skylinedan, slowduty80, slowleak, smokyred, star73, Stiletto6.0, TerminatorEngineering, texasmedic01, Tom S, toypuller, treyloco, twstmup, tyler886, WCTaco, wfodiesel |
| Thread Tools | |
| Display Modes | |
