Just a thought I have a 95 f350 ps long box crew cab 4x4 with 386000 I was thinking about swapping in a 01 ps in my truck good idea or a waste of time the only reason for changing to a 01is just for the upgrads and I'm getting to the point of rebuilding the engine in the truck. I know its goin to be a challenge would it be worth it?
With the 01 you have a chance of pmrs so I wouldn't risk it, plus stock sd turbo is known for surge so the only thing I would use is the hpop, maybe the injectors if yours are bad.
I figured I try finding a wrecked truck and go from their this is just a thought I'm only 70/30 on changing to an 01.could be a fun project and their seem to be way more upgrades with the newer trucks.
The only thing you get out of the newer engine is fresher cylinders maybe. You could end up with pmr connecting rods(bad). You will have no choice but to do an electric fuel conversion(more money) and you will get the dual idler pulley setup, split shot injectors(need a pcm flash to run them), and you will get the one bonus of a 17* hpop if it isn't damaged some how due to it being used and you don't know how the PO treated the engine.
Def a lot to consider. What would be some good power adders my plans are. Straight pipe to stacks(I like the way they look) banks six position controller(i thinks that's the one I been looking at) to start then injectors and upgraded hpop
107.4K members
