2006 6.0 with 2 balance codes help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 09-25-2012, 05:09 PM
jrex2506's Avatar
jrex2506
Online
Member's Gallery
has 103k on the clock right now, just noticed a miss in the mid rpm range, check codes at a shop and says balance codes for cylinder 3 and 6. also misfire code reported. previous owner said he code a misfire code from 7 and replaced the injector. just filled with fresh desiel and drove 25 miles home. no codes yet but seem to run a little better but still has a miss. just wondering where to go from here, seems to have good power, idles fine, no smoke or anything. could it be a sensor, wire harness or should i go straight to the injectors? thanks
__________________
2001 Ford 7.3 6" lift, ts chip, custom bumper and rack. intake,
Wife's 2005 F250, 6.0 crew cab short bed with 6 speed! studs and all the other goodies to bulletproof it.
Reply With Quote Quick reply to this message Go to the top
Old 09-25-2012, 05:15 PM
ghohouston's Avatar
ghohouston
Offline
whistle tits
Member's Gallery
Re: 2006 6.0 with 2 balance codes help!
It could be harnesses, but probably just injectors going bad
__________________
1997 F350 SRW CCLB 7.3 ZF5 4x4, 6637, 5" exhaust, ebpv deleted, Gearhead tuned, complete super duty e fuel setup. Hydroboosted, Lightning seats
  #3
Old 09-25-2012, 05:24 PM
jrex2506's Avatar
jrex2506
Online
Member's Gallery
how do i know if its them and how fast do i need to replace them?
  #4
Old 09-25-2012, 05:59 PM
justintimemoto's Avatar
justintimemoto
Offline
Member's Gallery
contribution balance test.....if there just dumping fuel and you run it long enough it could rune the cylinder
__________________
http://www.myspace.com/arcticcatsucks http://www.facebook.com/profile.php?id=1170374928
sucperchips flashpaq, banks ram air, 4"mbrp straight piped rcd egr delete leveled
  #5
Old 09-26-2012, 01:56 AM
seven.3psd's Avatar
seven.3psd
Offline
Member's Gallery
Not to thread jack but having a contribution code also on cylinder 5. Changed injector same issue. Also would like to know what the issue could be. having grayish smoke when accelerating truck can't even be driven how it is. Help me too.
__________________
1997 ccsb, swamps tunes 6 pos chip, cass stage 1s dynoed at 285rwhp before any of the following upgrades not sure what i sitting at now.Innercooled,qssb turbo,adrenaline hpop,beans idm mod.
  #6
Old 09-26-2012, 03:20 AM
jrex2506's Avatar
jrex2506
Online
Member's Gallery
well so far havnt noticed any smoke, not fuel in oil, just notice a miss, tank was less than quater so filled most of way up, and added some diesel additive, going to chekc the wiring tomorrow then maybe look into getting injectors. just aint noticing injector sysptoms like most people and drove the truck 30 miles after clearing the codes and no codes have poped up yet. any ideas? if not guess going to replace injectors....
  #7
Old 10-03-2012, 12:17 AM
jrex2506's Avatar
jrex2506
Online
Member's Gallery
ok got 2 new injectors ready to go in, here is my problem, did an injector buzz test and all turned out ok. got new codes one again for #6 injector code so gonna change that one. i did have a code on #3, but since i cleared the code it hasnt came back but now getting misfire code on #7 and it has already had the injector replaced. so should i change out #3 if i havnt got a code back yet or what could be causing the misfire on #7?
any help would be good also doing egr delete at the same time.
Human Verification
(View-All Members who have read this thread : 26
04 f350, 04La4iat, billbigsbe, bismic1, brute_mt, Bustedflush, cat420e, Dave-pls, Dbore, deerhunter625, duece, ghohouston, greyf350, jrex2506, justintimemoto, leechapple22, Mhatlen, NotMatt, Roush4_6, seven.3psd, Smoker05, sonnyy13n, Weatherlite, Wheelhop, wheelnrock, wvboy
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
