6.0 p2099 code - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 09-08-2012, 12:23 AM
keblmo
Offline
07 fx4 superduty..6.0
Member's Gallery
6.0 p2099 code
Will this low boost code cause the truck have hard starts? When I'm at a complete stop my edge is showing 1 lb of boost . Hoping someone can tell me what it might be before I pull the turbo.
Reply With Quote Quick reply to this message Go to the top
Old 09-08-2012, 02:29 AM
keblmo
Offline
Member's Gallery
Re: 6.0 p2099 code
Nobody???????
Too late I'm pullin it!!!!
  #3
Old 09-08-2012, 07:15 AM
keblmo
Offline
Member's Gallery
Re: 6.0 p2099 code
Pulled it looks pretty damn clean. No heavy build up and the unison ring is perfect . Gonna clean her up and check the boot tomorrow. Wtf was ford thinking putting that bolt way in the back?????
  #4
Old 09-08-2012, 11:41 AM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
Re: 6.0 p2099 code
Usually that P0299 code means the unison ring and veins need cleaned. I think that vertical back bolt on your 07 is easier to get out than the 03-04's which are horizontal.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
  #5
Old 09-08-2012, 01:20 PM
keblmo
Offline
Member's Gallery
Re: 6.0 p2099 code
Thanks for the response tool guy ..... I'm gonna clean it now!
  #6
Old 09-08-2012, 03:11 PM
bismic1
Offline
Member's Gallery
Re: 6.0 p2099 code
Sticking turbo may be the most common cause of the code, but P0299 is a code that can come from anything from turbo, ebp sensor or plugged tube, icp issues, high pressure oil issue, low side oil volume issue, ficm concerns (especially low voltage), failing injectors, low battery voltage or alternator issue, fuel pressure, egr valve, damaged MAP sensor or hose, etc. To know for sure will require more troubleshooting.
__________________
Mark
  #7
Old 09-08-2012, 08:47 PM
keblmo
Offline
Member's Gallery
Re: 6.0 p2099 code
Got it back in!
Works perfect... 24 lbs of boost (factory) no tunes?
Replaced the hot side boot ....88.00 bucks.
That's probably all it was to begin with but, the turbo's cleaned.
Thanks to the guys that did respond.
It was easier than I thought it would be.
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 48
03fathead6.0, 04 f350, 04La4iat, 06 f250 man, 06Diesel6.0, 1sd, 2 Stroker, 2005stroker, 95gasser, babyjones, bennett, bf9412, bismic1, brute_mt, Bustedflush, Chris's Dually, chrlskn123, daywalker, dbarnett42, ed3196499, eitmsmf, Gibrid4x4, Hytcrdnk, Jld, keblmo, ktmrydr686, Low Key, MColeman, Mhatlen, mxned, petesripper, Polkville, rbeckner27, Rob05F350, Rocky mountain stroke, shakeurazda, Sigep217, smokeum99ta, Smokin Stroker, SmokinBlueOval, Tjackson, tjoyce7250, toolmangary, tuhy, UNCLE DWAYNE, Wheelhop, wicked_four_play, zunk
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
