Nice. That's what I was wondering though. Kinda what I thought. That motor's so jammed up there's not much room for "pretty" things. Guess I'll have to make it pop another way.
not too blingy, but a few things here and there... it's got a little more done now, but haven't uploaded pics since the new boost tubes and intake elbow.
pic from a few months ago before i redid the map sensor, this is with a nonvgt turbo :
this is with the relocated MAP sensor and also ran steel braid to replace the rubber line to the MAP sensor:
I believe its because we removed the inner fans shroud on our trucks..but the square hole is there from the factory..the notch was done by him so that the emblem would go back on.
hard to tell from the pics, but it looks like the s/s braided line from the n20 solenoid runs over to the top of the oil filter housing... is that the nos line, and it just goes behind there ? or is that his oil pressure sending unit, similar to how his fuel pressure one is tapped off the fuel filter housing cover ??
and is that his fan control harness running thru the top of the radiator shroud like that ?
