2001 7.3 problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 09-02-2012, 07:51 PM
wills0173
Offline
Member's Gallery
2001 7.3 problems
Ive got a 01 7.3 with around 290,000 miles. The other day the power wire to the alternator got burned into and I replaced it. Every since then it's had a real rough idle, which smooths out while driving until overdrive then it goes to vibrating real bad, it shows no oil pressure at all and oil temp light stays on. It will still crank up and drive so it's gettin oil pressure to
The hpop otherwise injectors wouldn't fire and it wouldn't crank. My programmer pulls up a po603 code which says PCM failure and and throwing a p1211 code but no SES light comes on. Any suggestions to what my problem is? And I'm gettin alot of blow by from wastegate
Reply With Quote Quick reply to this message Go to the top
Old 09-03-2012, 05:16 PM
JohnDeereFarmer
Offline
Member's Gallery
Re: 2001 7.3 problems
Having very similar issues lemme know if you ever find anything
__________________
USMC 0311 08-Present OEF x2
2000 F250 7.3l 4x4
DIY6637, EBPV Delete (Housing&Pedestal), early 99 Wheel installed, Gauges.
  #3
Old 09-05-2012, 09:14 PM
vick97psd's Avatar
vick97psd
Offline
Member's Gallery
Sounds like when the alt wire burned in two it fried some other parts of the electrical system or at least some of the sensors/sending units. And the worst part with the pcm failure code might not be inexpensive and easily replaceable wires or sensor/sending units but might be the pcm got fried just like any other computer or electrical system they dont like to be shorted out. I would start with checking over the entire wiring harness with a fine tooth comb and replace the oil pressure sending unit/sensor since neither one will cost very much then its on to the pcm
__________________
97 F-350 CCLB 4x4 7.3L 267,000 CCV mod w/filter, 4" straight exhaust, ebpv delete, 6637 intake, 3" DP, Banks I/C, Racer X eagle T/C, Derale cooler pan, diy e-fuel, IDP bellowed up-pipes, inline spin-on trans filter, plate/fin trans cooler, boost, pyro, trans temp, fuel press gauges. Soon to come Swamps injectors, chip, idm, haven't decided on turbo
  #4
Old 09-06-2012, 10:44 PM
wills0173
Offline
Member's Gallery
just ordered sending unit/sensor from o rileys. will have it tomorrow. where is this located at on the motor and how bad of a job is it to change out
  #5
Old 09-07-2012, 01:23 AM
vick97psd's Avatar
vick97psd
Offline
Member's Gallery
Oil pressure sending unit should be right on top of the hpop reservoir unless they moved it between obs and super duty i domt remember if it is there last time i looked at a super duty
  #6
Old 09-07-2012, 10:54 AM
wills0173
Offline
Member's Gallery
I searched some YouTube videos las night and it's showing one on top of the hpop and a small wire/probe type deal on top of where the oil filter screws on. Maybe this fixes my problems
  #7
Old 09-07-2012, 11:00 AM
wills0173
Offline
Member's Gallery
Oh and to add to this post, right after this happened I checked all fluids, oil was rather thin so I did an oil and filter change hoping that it may would change the way it was running since it has hydraulic injectors but it changed nothing. Is it possible for the hpop to loose prime cause the truck to run as if it has a dead cylinder or misfiring?
  #8
Old 09-07-2012, 02:20 PM
vick97psd's Avatar
vick97psd
Offline
Member's Gallery
Yes the oil pressure is on hpop reservoir and the oil temp is on the oil filter/oil cooler header. As for hpop losing prime i dooubt that is your problem, that would cause an extended crank or hard start issue. But the rough idle and bad vibration could be one of the injector harnesses. Check the wiring harness going into the valve covers if that is ok pull the valve covers and check the injector/glow plug harnesses they could have a short somewhere causing this.
  #9
Old 09-07-2012, 11:35 PM
wills0173
Offline
Member's Gallery
Just changed out the oil sending unit. Still running rough and still showing oil temp light and no oil pressure. Unplugged the harnesses on top of the valve covers one at a time and try both changed the way the truck was running. Idk, what would be next on the list?
  #10
Old 09-07-2012, 11:52 PM
vick97psd's Avatar
vick97psd
Offline
Member's Gallery
As much as i hate to say it sounds like it might have fried the pcm check the entire engine wiring harness for any chaffed or burnt wires and then i would try to find someone with the same pcm code to swap and see if that fixes it before you buy one and try swapping the idm to just to rules these things out before you shell out the cash for.non returnable parts
Human Verification
(View-All Members who have read this thread : 207
'94IDITurbo7.3, 01pwrchkn, 01REDSTROKER, 02 CCSB, 03f550, 07hs2000, 1hvyhammer, 2001-7.3Liter, 2002 E350, 2002f-250, 2002FordPwr, 2BZ1, 300,000 and counting, 4BigGreen, 4wydnr, 521TURBO, 7.3, 7.3 Blackout, 7.3 problem, 7.3 total chaos, 7.3 Whitey, abbottfarms, ajfetterman, andrewv_24, ArmyGuy45, aussie powerstroke, barrakudaman, Bdickey, bholley, big nasty, bigb, BigRedNewfie, Bill R, Biscayne, Black Pearl, Blue2002, Bob63, Bobs 7.3, Bombsquad450r, brantd00, Brasquatch, Breacher, Brian918, brucem, bushhogger, camaroicoc, camp nh, Capricious, CHUBS88, chugluglug, Clarence_Carter, codykthekilla, COFG-28, ColeTrain45, Corey Hudson, countylinefarmer, coyote1, crichers, critter011, cteam78, CTFFEMT, Curtsturbo331, d-selpowereddiebauer, davegiorgi, deranger, diesel_84, dkrajcovic, dogmaticus, dtrojcak, DUESLER, duner405, dustin34520, EastEndLou, Elgin MGP, f25070, f450dozer, farmboy93, farmer09, FCR10, ford4life76, Fordguy26, Gbdjunior, Gcashwell, ghohouston, godzillas dad, grimF350, gtakamoto, Haccch, haulin2000, HeadHunter, hottspyder@yahoo.com, hydro man, IApowerstrokers, jab7.3l, jamesfossett, jamesmeek6, Jbolen323, jdinevens, jdw1, Jellyroll22, Jeremiah25, jess, jestersv, Jimbostoys, Jimmy4570, jimmyb, JohnDeereFarmer, joness, jpaitala, jth4570, juvenile9, kaker123, Kienan327, kilapapipa, klos, kmesaeh, kstone2020, KYkickinit, lariat7.3, lght1, lilgreen97tj, little_town_biodiesel, Luke909, Lup3to, maritimer10, Mark Kovalsky, Market, Matt-F350, matthewb, MidwestOBS, Mike96ZJ, mjpage69, modes, mpirtle81, Mr2_nut, mrtoddy, nah308, navistar45, Nodge, NorCalDiesel, Northcountrywood, Onawave, Oscar1017, pappa b's powerstroke, PETERC, PoorMansCat, portillo, Powerstrokinfirefighter, Project20v, pup 7.3, pursleybp, raptor, RAYZOR, rebel4x4, Rescue48, richard720, river rat, rockcentral4wd, rohleder644, Schaefer7.3, scottambrozic, SD01WD, shmokenpstroke, shvlhead78, silent64, skeetreecetw, slick76, slingshot, smerleau, Smith505, Snyda88, sokdaddy444, Southpaw, srswain, st1speed, starvinmarv, strokepower, strokerford, Strokin450, Strokinstrong, sujumptd, Superstroker156, swansonb, Terraford, terrye, TF99Powerstroke, ToMang07, towsurfer, Tprov, tswickedboy, TWIM, txrlk, vick97psd, viper101, VooDoo, Wasabi, weebieboy, WhiskeyTangoFoxtrot, wills0173, Witenite, wvrrcarknocker, xzwarhawkzx, yellow dog, Zac
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
