I FINALLY got my air horns on.
I wired the a momentary switch to actuate the horns. I just ran a fused wire from fusebox. than other wire to horns. It was 2amp, but it blew. I tried a 5 now. Do you think its safe?
Now to turn on compressor, could I use a normal on/off and wire it the same? Its going to a relay, which switches compressor on. Is there any reason to fuse it more than 5amps?
