Can anyone give me a breakdown of the parts/kits needed? I basically just want the 350 rear height and a leveled (a little downward rake is okay) front. I've searched multiple forums and can't find a solid answer.
You need the rear blocks from a 350. Theyre 3 5/8 on an inch tall or just get an aftermarket 4 inch tall block. Need longer U bolts too. I say do that and see how it sits. If you want to raise the front later there are a lot of different ways. Springs or spacers. Spacers for the top or the bottom of the spring. If you raise the front youl need to get and adjustable trac bar and alignment cams for the top ball joints.
You just need a 2.5" level kit..will come with everything needed..PM me we have everything.
