6.0 coolant leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 06-20-2012, 01:50 AM
5.0bronco
Offline
Member's Gallery
6.0 coolant leak
hello my 2006 powerstroke has just began to leak coolant, it appears its leaking externally from the driver side cylinder head at the rear of the engine. i was wondering if any one has seen this problem? also the botton of the lifter valley is wet also and it appears to be coolant. could it be leaking from my egr delete and running down my lifter valley and then running down the back of my cylinder head? the truck doesnt blow any white smoke on start up or any other time. any suggestions where to start first would be greatly appericated.
thanks,
Jonior
Reply With Quote Quick reply to this message Go to the top
Old 06-20-2012, 01:53 AM
06kingranch37's Avatar
06kingranch37
Offline
Member's Gallery
Re: 6.0 coolant leak
Check the hose going to the heater core mine rubbed threw on the ficm the coolant line off the bottom of the degas bottle
__________________
2006 f350 has 205/100 warren injectors custom fuel system a1000 regulated return, s368 batmowheel , banks tecnicooler,58v ficm, afe intake, single 7 inch miter stack 35 12.50 18 toyos, elite stage 1 camshaft, sct live wire with warren diesel tunes, 4 inch lift kit ,
  #3
Old 06-20-2012, 02:09 AM
5.0bronco
Offline
Member's Gallery
just checked the hose going to the heater core and no luck that is not the leak
  #4
Old 06-20-2012, 04:53 AM
5.0bronco
Offline
Member's Gallery
also some times the truck has a high pitch whistle that doesnt sound like the turbo some times when im accelerating. any suggestions would be appericated!
  #5
Old 06-20-2012, 12:53 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
That "whistle" doesn't sound good, that usually means the cap on the degas bottle is blowing off pressure. I think I would T a pressure gauge in that 3/8's hose that goes to the radaitor from the degas bottle so you can see whats going on with cooling system pressure.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
  #6
Old 06-20-2012, 04:41 PM
5.0bronco
Offline
Member's Gallery
thats what im gonna do tonight and hopoefully that is not the case, it appears that my drivers side manifold is leaking so hopefully that is the whistle
  #7
Old 06-22-2012, 12:28 AM
5.0bronco
Offline
Member's Gallery
i just ran the truck with the pressure guage hooked up and ran the snot out of it and i only hit 3.5psi on my guage. the truck has only leaked coolant once and it was only a puddle about the size of a half dollar on the ground. im wondering if the hose on my egr delete might be leaking and running down the lifter valley and dripping down my cylinder head?
  #8
Old 06-22-2012, 12:30 AM
5.0bronco
Offline
Member's Gallery
also i used 3 different guages to make sure i wasnt using a guage that was off.
  #9
Old 06-22-2012, 01:29 AM
nrook's Avatar
nrook
Offline
Member's Gallery
Mine did the same it was the rubber tube that comes from the egr cooler to the oil cooler running down the vally dripping from where you describe
  #10
Old 06-23-2012, 05:03 PM
5.0bronco
Offline
Member's Gallery
just cleaned the coolant off the engine and let the truck sit for a day and the coolant appears to be leaking from the head gasket
Human Verification
(View-All Members who have read this thread : 126
03miracle60, 04 f350, 04krpsd, 05_STROKE, 06f350stroker, 06kingranch37, 06_WhiteBull, 2 stroked, 2 Stroker, 20007.3psd, 2006powerleaker, 350blk6.0, 5.0bronco, 6.9to6.0, ajennings, amdriven2liv, AshevilleEngine.com, ayrn, Beekeeper, bennyboy, bigdaddy60, BigMike, bigrngyj, bismic1, Blacksmith01, blair, blwnmstgt1990, BMWgoneWILD, boostintalon, boss_302, breadman, bulldog6702, bustednuckles, bzy livn, B_theworm, claycapps, cloud26, colekym, daves02, daywalker, Deerezilla, diggersps, Dirty outlaw, dits145, Dodgethebullet88, durafish, elevateloren, Enthusiast, ernieb143, FoolishPride, Fordguy26, Fox'sFord, Fyrman25, georgia diesel, gguartuche, gtmustang00, Honda30, hotrodelrod, HUCKit, hustler315, jakemono, JBW48, jessduen1, jhunter14, Jomull55, jrex2506, jrf350, justind, KHR6.0, km335, ksieckmann, Ksop2001, leechapple22, m j, majek5, mantis118, mason93, matthewd11, meandog06, miller45103, mjcolemn, MrBill1, muddy650, mx185sw, Natos, new2deisel, Normalario, nrook, NYC F-350, oldblue, oshmago, PCL, plumber802, Poh, Polkville, range91, RAUD, redjet, Rustymx11, ServiceTech, shadow6.0, Slopoke, Sndwrkr, SpadyA, StrokeThis8, strokinout, Stumppy, stysinjimmmy, t.r.p., tatertot, Tdoa, teddy's6.0h, The Dude, Thunderpimp, Tj561CO, toolmangary, tuhy, usmcnewbee, webb06, willholl79, Wyo, xp1ik05, xsfpns, z28fred, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
