I dont care if you wantch the videos or not but please click the links to help get the "hits" up.
for the first 20,000 miles (plus or minus) I was a Major Ecoboost fan, since then my thoughts of Ford and This engine/truck have changed a little. What would you guys do about this?
Starting around 20k miles my truck started missing while sitting at idle, a random CEL (which would not shop up on a scanner after it went off), a random reverse camera issue where it will not come on (or when it does come on it is black and white and very grainy looking), sometimes while trying to get onto an on ramp and gassing the truck hard it would fall on its face and return to idle (yes, while merging) and you would have to let of the gas and slowly reapply, when traveling at highway speeds the truck would mis or start stuttering and shaking (bad enough the steering wheel would shake up and down at least a 1/2" (it happens in 5th and 6th gear then at about 32k miles the truck would go into limp mode while trying to pull a 6*10 single axle angle top lowboy.
I took it to the shop (on 4/24/12 and had a few small things fixed but all of the above was on a list of problems I provided to the service adviser. A week later (4/30/12) they called me and told me to pick the truck up. I went and got it and on the repair order it said they re flashed the PCM and installed a new cat. On the way back to my office I could feel the mis at highway speeds again, i just took note of it and kept going begin i didnt have time that day to mess with it. That evening after leaving work and trying to get on the interstate it started the return to idle crap and about got me creamed.. The loaner truck I had borrowed while my truck was in the shop was going to be tied up for a few weeks so I couldn't return it to the shop yet. All of this was on 4/30/12.
Thursday (5/3/12) I was headed back to my office from a meeting and my CEL came on again so i pulled into the dealership to see if they could pull a code while the CEL was still on, I was afraid that if the CEL went off it would not store the code like before. They jumped on it and it had three codes (p0300, p0304, and p0430) the tech gave me a print out to bring back when I could leave it again and I left. The print out has a report that says "cylinder 4 misfire detected)
On 5/21/12 I tried to pull a trailer to work with me hauling my lawn mower and the truck went back into limp mode and after about 20 miles it had lost all power.. I knew my Dad was either right in front or behind me so I called him and he come and towed my trailer to work for me. I took the truck back to the dealership that day and dropped it off again, this time i provided the same list to the SA and had updated notes written on it about the things that were fixed and the things that were not fixed. It would probably have happened sooner but my wife had a baby on the 8th and i took a week off of work and then didn't do any outside work the few weekends following.
on 5/29/12 the SA called me and told me I could pick up my truck, I asked her what was wrong with it and she said she didn't know and it was not fixed. As you can imagine I started asking questions. She informed me that Ford wouldn't authorize them to throw any parts at it because they was not sure what was wrong with it but they had a TSB that would be out in 4-6 weeks and that would fix it. I asked her what I was suppose to use for towing in the mean time and she said he didnt know. I then called the service manager and spoke to him about the issue. He told me the same thing and told me they would not be able to give me a loaner vehicle because ford wouldn't pay for it. Because I could drive my truck.
I called ford and started a case and was told the regional rep would contact me in 24 hours.
When the rep called me I was not at my desk so after hearing what she had to say I asked her If could call her back from my office phone. when I first spoke to her she told me that would not give me a loaner vehicle because I could use my truck for it's intended purpose and that the truck was not designed for towing. I about lost it... I told her have you seen a single ecoboost commercial? at this point I asked her If I could retrun her call and record the conversation becaues I was not believeing what she was saying.
Out conversation is below. I called her and told her I was recording and then this started...
since then I have spoke to three other reps that tell me the same crap and refuse to offer me a vehicle to drive until mine is fixed... i pull a small trailer every week end and they refuse to give a crap but yet they advise me not to drive in limp mode...
here it is in limp mode
This is the new ecoboost outboard edition... sounds like a freaking boat...
here is the reverse camera issue... this is after they have already "fixed it' once..
It started missing again on the way home from work so I took these videos...
__________________
__________________
