Dash Lights, Windows and Radio Problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 06-07-2012, 02:34 AM
BlackHogDown's Avatar
BlackHogDown
Offline
Member's Gallery
So I have a 02 CCSB 4x4 7.3l that just turned 55k and the dash lights haven't worked since I bought it a year ago(only the gauge cluster lights). Then lately (occasionally) when I get in the truck I start it and the powerwindows and radio take a minute or so to work!? I'm not good with electronics but I have checked all the fuses and they are good. Any suggestions?
__________________
2002 F350 Crew Cab Lariat 7.3L 4x4 8inch Lift 37 Military's
Reply With Quote Quick reply to this message Go to the top
Old 06-07-2012, 02:57 AM
ColeTrain45's Avatar
ColeTrain45
Offline
Member's Gallery
Re: Dash Lights, Windows and Radio Problem
Gem module??
  #3
Old 06-07-2012, 02:39 PM
BlackHogDown
Offline
Member's Gallery
Thanks bud looking into it now
  #4
Old 06-07-2012, 08:45 PM
7.3's Avatar
7.3
Offline
I'm A Beast
Member's Gallery
the duck in your avatar has a camel toe lol.
  #5
Old 06-07-2012, 10:23 PM
terrye
Offline
Member's Gallery
I have a 2003 F350 4x4 6M with 275,000 miles.
I have a similar problem. ocassionally when i start the truck the windows, radio and fan do not work for awhile, then eventually they work again.
I was installing electrical on an airplane with some technicians the other day as we were troubleshooting some electrical wiring problems and i mentioned it to the technicians. They said my problem was a bad ground or a recessed pin in a connector or a short. Someone needs to look at a wiring diagram, figure out where the grounds and connectors are that are common to these systems then check each one out looking for recessed pins, a corroded or loose ground or some worn wiring.
I know there are a few guys that get these same problems and have never heard of someone that actually fixed it. Let us know if you have any luck!
Terry
__________________
2003 F350XLT Shortbed CrewCab 4X 7.3l 6MT.
MODS:
07 Facelift. WW2. 65 HP PHP tow. ATS ported housing. Turbomaster wastegate controller. Bellowed up pipes. Midwest Trans short throw. 2" Edge Level Kit. AFE stage II. Hellwig 1 1/4" rear sway bar PN 7636. Autometer Ultralight guages. South Bend Clutch - MU 1944 6 speed Con 0. 295,000 miles.
  #6
Old 06-08-2012, 03:31 AM
mjones's Avatar
mjones
Offline
Member's Gallery
leaky windshield my 99 has no bright lights unless i jockey on the fuses and if it gets really wet the trans doesn't shift right check the hole where the wiring harness goes through the firewall
__________________
1999 f 350 ext cab racer x tc and valvebody dp tuner 60tow 80e 120race 140 extreme 04 grand cherokee
1999.5 f350 crew cab beans tunes
  #7
Old 06-08-2012, 06:06 AM
Dieselpop
Offline
Intelligent Burro
Member's Gallery
A leaking windshield will damage the GEM module and the fuse panel. I would start by fixing the leak. Then remove the fuse panel from under the dash. The GEM module is attached to the back of the fuse panel. Separate the two and clean the contacts with a brass brush and contact cleaner. You will probably still have to replace the GEM but maybe you can salvage the fuse panel.
__________________
E99, F250, 7.3, CCLWB, Auto, manual 4x4, AIS intake, AD injectors, PHP FU, AIC, 3:73 gears. Autometer Gauges - (EGT, Trans Temp, Boost), Edge CTS
  #8
Old 06-15-2012, 09:35 PM
LCRIII's Avatar
LCRIII
Offline
Member's Gallery
The 2002 & 2003 Superduty have an accessory delay relay built into the instrument cluster. It is integral and non-serviceable. In hot temperatures they are bad about sticking
causing the windows,radio and other accessories to not operate. Usually they will unstick after few minutes, if not the instrument cluster (gauges) needs to be replaced.
  #9
Old 06-16-2012, 03:40 PM
NorCalDiesel's Avatar
NorCalDiesel
Offline
Member's Gallery
.. and you're looking?
__________________
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
  #10
Old 06-20-2012, 08:01 PM
terrye
Offline
Member's Gallery
Where exactly is the accessory delay relay? is it in the fuse box?
Thanks
Terry
Human Verification
(View-All Members who have read this thread : 99
!!!PainTrain!!!, 2000Censtroker, 2002f-250, 7.3, 808diesel, 98stratusryder, ad40434, ASTRO, Badland, big trucker, BigJake, billmoody1, BlackHogDown, blackmagic, blaze42069, BootZ0360, Boydog, brandothi, caseyk, caspower, celltech, chevelless414, chris 0., Cloverleaffarm, ColeTrain45, connor926, cterry, dbincolo, Denver, Derek2001, dieselboy01, Dieselpop, Dirt_99, eib, fastedy, FCR10, Ford_7.3, g2shuck, gmdriscoll, highlandre, hydro man, iceberg, IHPowerstroke7.3, IL7.3 Powerstroker, itsmyduty, jestersv, jhruzek, Jimbo*, jimiii, JLowry, Jonesin, Jordison460, jrjax, jtgf250, Kohrnholio, Krawlerhauler18, LCRIII, lhrboone, m j, mainer815, mc44, meat, Mini-Stroke..., mjones, mx185sw, mx929racer, neher72, No Regrets, NorCalDiesel, Northcountrywood, Old OutLaw, otis_301, POWERSTROKE2311, Primaris, retiredsparky, rfrostick, Ron's power stroke, Rowe, RyanG85, S00TLYFE, smokedyvr, southmike, strokepower, sxcross, tbolt, TD2024, terrye, ToMorrow44, tractorman1365, turbostroke02, txgp17, vis152, Weatherlite, weebieboy, wesconjr, WyoUltra, yz85rider2002, Zmann
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
