i have a leveling at a leaf which brought the front up 2.75 inches and i also have a procomp 2.5 inch shackle drop in the front. IN the back i have a f350 block with a two inch block on top of that. Could i fit 37's if i pull back the fender wells?
I would think so, Ive seen people install them on a 4inch lift....might rub a little bit, but it shouldnt be to bad.....got any pics of ur truck....Id really like to try a shackle up front, just dont have a lot of experince with them...
Whether they will fit or not depends entirely on what wheel offset you are running. With that said, ditch the stacked blocks as previously mentioned. I also really don't like the stacked leveling kits up front since it sounds like there is nothing to correct your steering geometry.
