96 powerstroke as no low end power - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 06-04-2012, 04:17 AM
Stihl pulling
Offline
Member's Gallery
I have a 96 f350 with a 7.3. This past weekend I took out the e4od an put in a ZF542 5 speed. I went to drive the truck and the engine has no bottom end power. I have to take off in first and if I try to do second I have to ride the clutch pretty bad and the engine really lugs hard. After 800 rpms it does fine and has plenty of power. The fuel pressure is holding at 60 psi with a SD pump conversion. The only other mod the engine has is a edge evo. I don't know if it would be the PCM or a hpop or something else
Reply With Quote Quick reply to this message Go to the top
Old 06-04-2012, 04:21 PM
Highbeam
Offline
Member's Gallery
Re: 96 powerstroke as no low end power
AFTER 800 rpms it does fine? The idle is 675 for my 7.3. You can't expect much power at idle. Turbo spool up isn't even really happening until well over 1500.
You might just be used to the torque converter slipping which allows the revs to climb fast on an auto trans.
__________________
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
  #3
Old 06-04-2012, 05:00 PM
Stihl pulling
Offline
Member's Gallery
I know it shouldnt have a lot of power down low, but i pulled 5000 lbs this morning and its all i can do to get off the line in first. With the truck empty it pulls the engine way down and it lugs real bad at take off. I feal like its not getting the fuel it needs at low rpms the truck has 4.10 gears and stock tires so it shouldnt have any issues there. At higher rpms it does great and will leave a little smoke but down low its a dog. Thanks for the input ill need all the input i can get
  #4
Old 06-04-2012, 10:12 PM
countryboyrob
Offline
Member's Gallery
Step 1. Click thread tools.
Step 2. Click move thread.
Step 3. click the obs tech section.
Done.
__________________
02 f250
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 49
1SLO GT, 97-7.3powerstroke, 97WhiteGhost, Aminator, BigBluediesel08, BIGCOUNTRY418, camd94234, carrj66, Cclinton, CSIPSD, DIYMechanic, dragonboi, dzlstroker, Erik_Lee, ghohouston, glovemeister, golfer, Highbeam, JakePSD, jdolliver, jeichert, jeremiahmercier, Jjona5, Jlh, jmbosh, jmsmith76, jrbrock, leepfrog, Macchina50, NWPAStroker, poon, portlandareae28, Power97Stroke, PowerstrokeMudder82, rd2boys!, Ron's power stroke, Stihl pulling, strokethis96, sturbo90, t.r.p., theSLEEPER, Tom S, toolmangary, tyler886, Wilson444, zappattack18
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
