Does anybody have any info on these bad boys? Holderdown performance has them on their website for a little under a grand, jw if anybody is running one and how well u like it? And how does it sound?
The Trusted Performance turbo im running is a Borg warner 64/71/70. RCD's turbo's are borg warner and so are II turbo's. Everyone just makes their own changes to them. You might be able to get the turbo for just under a grand, but you gotta buy a pedistal, drain line, feedline, and adapter flange...which will be over a grand.
It's over a grand just for the stuff u gotta have for the turbo? Or it would just Be over a grand after u buy eveything for it? I was jw how good they were and how they sounded, I like the way my 03 sounds but it's stock so I can only get so much out of it ya know
I had a stock turbo on my truck you can get more out of it than you think i was getting 48lb of boost with power pup tuner but stock injecters didnt last long.
Yes Most turbos you see on the market are Borg Warner turbos that have been given their own twist and rebranded. This is not a "drop in" style turbo. You will need some other parts as well. Let me know if I can help.
well maybe everyone else's turbos are over priced. Mine was $2400 for the 64mm. I believe RCD's 64mm is around $2200 or a little more. Most places I've seen just the turbo for around $1500-$1600
powermax isnt much bigger than stock. It is also a vgt turbo like stock. These turbos are a non vgt and depends on what you want to do with the truck to get the correct size.
is there an option to get a polished compressor cover for the Borg Warner turbo's you guys sell? $949 is a smokin deal for just a turbo....wish you guys had these when i was looking. If i could sell mine i'd love to try the 64/68/83 T4
Yes we can have it polished I would have to check on the price though.... Thanks for bringing that to my attention I should add that as an option to the webstore.
I may be selling my billet wheeled 63/68/70.
I have way too much fuel for such a tight housing now.
Trying to find an .80 or bigger housing...may as well get the whole turbo, cuz its almost as cheap...
You can find "Box" BW turbos for like $650.00
Anything fancy, and the price sky rockets from there. (Gawd help ya if you wanna change turbine housings...)
