6.0 BLOWING BLACK SMOKE!!! HELP!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 05-14-2012, 02:43 PM
03fathead6.0's Avatar
03fathead6.0
Offline
Member's Gallery
No it is not by intention or anything else in that manner. But my 03 6.0 is blowing black smoke out of the exhaust like a over fueled 7.3 with a straight piped exhaust. Started this weekend while pulling a load (Not even a big one) just a 12 foot flat bed trailer with about 3,000 lbs of brick on it. Any way the reason i even noticed in the begining was by looking the mirrors and realizing that smoking every one and anything out behind me. A quick look down all gauges were in the norms. Not even a check engine light. Only issue i was having with the rig was a rough idle with it in gear. Truck made it home smoking the entire way needless to say. I start to tear into the engine sunday, first theing i noticed was soot all over the top of everything in front of the turbo, i pull the intercooler pipe, boost boots, and realize that there is oil or something inside of them. PLEASE HELP ME OUT HERE!!! i have no clue what this might be and have been regulated to riding my motorcycle back and forth to work which would be no big deal if i was still stationed in california, but here in ohio the rain is coming and no one likes to get that wet on the way to and from work... I am just looking for area's to start looking at more closely before i rip all the way into this thing... Thanks for any help
Reply With Quote Quick reply to this message Go to the top
Old 05-14-2012, 02:55 PM
Term3's Avatar
Term3
Offline
'05 Excursion
Member's Gallery
Pull your EGR valve and take a look at it and inside the manifold.
__________________
  #3
patrickke
Offline
KEM Sales & Support
Member's Gallery
Re: 6.0 BLOWING BLACK SMOKE!!! HELP!!!
Do you have AE?
__________________
KEM Racing
KEM Performance
  #4
Old 05-14-2012, 02:58 PM
DieselDZ's Avatar
DieselDZ
Offline
Member's Gallery
The oil in your Inter-cooler pipes is due to the crack-case ventilation system. A CCV reroute will take care of that. it basically dumps oil mist from your valve covers into the intake. It sounds like your turbo may be shot or going to be dead very soon. Any shaft play? do you have a boost gauge to check?
__________________
2008 F-350 Lariat EGR Delete, Cold pipe, CFM, H&S, DPF/CAT Delete, Elite 71mm, Elite Springs and push rods, Built trans, Studs, Up pipes, 4" exhaust, Traction Bars
  #5
Old 05-14-2012, 03:53 PM
Dave's Avatar
Dave
Offline
FNG
Member's Gallery
CCV reroute wont do anything for this man.
Pull your EGR valve. Is it wet?
__________________
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
  #6
Old 05-14-2012, 08:37 PM
03fathead6.0
Offline
Member's Gallery
Will pull the EGR valve out tonight after work, and the turbo as well. Take it i am looking for crap inside of the EGR valve, looks like the delete will be coming sooner than i thought and the turbo oh geeze, are the stockers rebuildable on this truck? Just looking for a cost effective IE within reason fix to the issues at hand. Can not afford a full rebuild with power adders at the moment...
  #7
Old 05-14-2012, 09:15 PM
03fathead6.0
Offline
Member's Gallery
Oh just a quick question as well how would either of those produce exhaust soot and leaks in the engine bay? Please excuse my ignorance just wondering is all... Reckon this is going to be one hell of a learning curve...
  #8
Old 05-14-2012, 09:49 PM
ftb28
Offline
Member's Gallery
When my egr went bad it didnt black smoke at all... so idk what the point of pulling the egr would do. Sounds to me your turbo is just leaking oil and you exhaust is burning it.
__________________
03 F250 ccsb KR FX4. Swamps 58v ficm, stock straight pipe. Wheels 20x35x12.5 Nitto Trail Grapplers.
  #9
Old 05-14-2012, 11:55 PM
Fox'sFord's Avatar
Fox'sFord
Offline
Member's Gallery
Burning oil is blue smoke not black.
Bad exhaust leak in the upipes? Are you making any boost?
__________________
06 F250 leveled on 35's, studded, deleted, Innovative, 4" straight pipe, banjos, spring, ccv w/can, elc w/ filter, DVD/sat/nav in dash, kr running boards, bull bar
  #10
Old 05-15-2012, 10:05 AM
ajfetterman's Avatar
ajfetterman
Offline
Member's Gallery
Did you put on a new down pipe when you did your exhaust? I would go through and retighten all of the new exhaust clamps. If you did put on a new DP then I would also make sure it seated right.
__________________
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
Human Verification
(View-All Members who have read this thread : 358
01Stroker4x4, 03fathead6.0, 03whistler, 04 6.0 Hambone, 04 f350, 04La4iat, 05harley, 05_STROKE, 06 f250 man, 06-6.0 stoker, 06kingranch37, 06regcab6.0, 06_WhiteBull, 086.4xcab, 1911medic, 1999 7.3L, 19Dually97, 1badpsd, 1Flstfb, 2005stroker, 2Dstorm, 300,000 and counting, 350blk6.0, 494doug, 4d4life, 5.0bronco, 501outlaw, 6.0&SN95tagteam, 6.0_psd, 6.7TX, 6.9to6.0, 7.3 Blackout, 7.3psd1999, 84mudder, 91forddiesel, 93Reddually, 94.5 Stroker, 95gasser, 97-7.3powerstroke, 99coalroller, Agjake11, ajennings, ajfetterman, AK1, Alvapowerchoke, amdriven2liv, arctic89, arcticstroker05, Atc-Eric, Aubskee, b2, bahenry87, Batt5, BayouKR4, bgc, big nasty, BigBluediesel08, Bigbody250, BigD2623, BigKid, BigMike, BIGN, BigRig, bigstrap3, bigvern64, Binderpower, bismic1, BKiggins, bkingsoda, black02l, BlackCloudMafia, black_pstroke, bladesprague, bluethunder2006, BrahmerTamer, brute_mt, btcook1, btomassacci, Bubbawagsf250, bubz37, buddhascuda, Burg460, Bustedflush, Bustedknuckles, ByrdDog, cadwell08, caleb90, catman70, cavscout075, ccf350stroker, cement6.0, cfd f-350, chappy, Chris's Dually, chrlskn123, cjames, Clatterindiesel, clint2309, cmca swartzkrautheim, Codydiesel, cody_dempsey7.3, colekym, Cory2537, cporda, crossroads diesel, ctstroker1080, cummins kid, cumminspower, c_ratkovec, Dane1985, Dave, Dave R, daywalker, dblhock, Dbore, Deerslayer42694, dentexpowerstroke, Desertdweller, Devilstang93, Dieselboy, dieselboy01, DieselDZ, DieselPowrJunky, Dirt Floor Poor, Dirtyryder, dits145, DNichols3288, dominick gentry, Donetalking, doofpowerstroke, douglash, downfour, dp42, dp_stroker, drrock, DrydenT, dunatic, DZLAL, E99Superduty, el guapo, elky57, elwood blooz, Extended Power, eyoung, f-150_xl, F-250-Owner, F-350 Explorer, f350jim, FarmBoyStroker, FarmRig, firedobbie, fishman06, florida 6.0, flybykota, FoolishPride, football3295, Force2354, ford rules, Ford6.0L, fordboy11, Fox'sFord, fpOwerstRokeD, ftb28, galiv, ghamrick, ghohouston, goosyboy, GraveDigger88, greenbeast, Grey6.0, growntexastuff, gtmustang00, gunfreak25, HankyD, Harley Strokin', harrisford, HARTATTACK, hawkeye, hill_billiez, HoldeNatPower, hoosier6.0, hudsonb, IdaGlyde, IHPowerstroke7.3, indiana lineman, iracemx6, ittech729, jacmurr, jamisgood, Jason.Horath, JayMoney, JD F350, jdolliver, jdsf350, JeffReynolds, Jeremy, jessduen1, JimmyJfd73, Jlh, jmwelton, joestroo, JOE_JOE, jordan572, Josh4683, jparker, jtgf250, jth4570, justind, kenk, kingstroke, ksieckmann, ktmrydr686, kyle882, LadderDog, LAredneck6.0, Low Key, lubeowner, macoyle, majek5, mantis118, Marvelous Marvin, mason93, mastrkee, mattman_13, maverik2711, MDpowerstroke, mglass, Mhatlen, MidwestOBS, miller45103, mjcolemn, mkelly, Monster758, moose7.3IH, mosborn, muddynoll, Mustangl3, mx185sw, mzender, nedkin01, new2deisel, NH OIL BURNER, Nico963, no-tel-in, Normalario, no_pistons7, nrook, Nutz, o4ep3civ, OBS F350, ocunit42, oh3 6oh, oldbluef250, pa-powerstroke, patrickke, pccurr, peanutsfive, plumber802, PolanD RuNz iT, Polkville, POORBOY1964, power strokin, PowerPerformanceChainsaw, powerstrokedkid87, Powerstrokinfirefighter, PPE'dPowerStroke, precisionstroke, PSD2190, psdri, rb12405, Rbloodhound, Rdh605, redneckcmt, RescueF250, rettus72, RHCDIESEL, roadstar, Rocky mountain stroke, roller, rooster, RRF985, Rustymx11, sargepep56, scooby, seven.3psd, shadow6.0, Shep, SirStrokeAlot, skeetreecetw, skinny, skivette73, Skpph, Slated4Greatness, sleeper_sicksoh, sly1types, Smokin Stroker, smokin99stroke, SmokinBlueOval, Sndwrkr, Sniper32, soapy, Softballguru, speedkills502, splatranger95, srtmodr, steel, Stevenmc08, stik, stoke17, straightaxle, streetscrapin16, Strokeme99.5, strokepower, Strokin 35s, Strokin450, strokin93, Stumppy, SuperBlazin, svorob, t.r.p., tallpaul, tatertot, tecelec1, terry c, The Dude, The Gray Mule, Thunderpimp, tl1000r, toolmangary, toverbey21, toytruck, tuhy, Turbodiesel6.0, twayne05, txffemt, Tyler R, tyler886, U235a4, vindiesel2, Wangfu12, wargle, webb06, wesTXhb, white00strokerks, Wilson444, wispy, Working K-9, X-MAN, xsfpns, Ycanti, yodermanks, yz85rider2002, ZaC851, ZCMiller, zeekzimm85, zilla68, zman1357, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
