6.0 Oil Leak at turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 05-10-2012, 02:54 AM
SaNnDnSurF's Avatar
SaNnDnSurF
Offline
Stock Sucks!
Member's Gallery
Truck leaks oil right under the turbo you can see a small puddle, replaced turbo drain o-ring and still leaking the mechanic I use works at ford is acting like he's stumped only leaks down the back of the motor while the truck is running and for a couple mins after it shuts off any suggestions here? 05 6.0 110k miles
__________________
05 CCSB 6.0
ARP Studs and Egr Delete
8" Rize
22" RBP Wheels 37" Toyo M/T's
AFE intake & 8" Mbrp Stack
SCT With Innovative Tunes
RBP Grille
Amp Steps
And some other bling
Reply With Quote Quick reply to this message Go to the top
Old 05-10-2012, 03:36 AM
mastrkee's Avatar
mastrkee
Offline
Jackleg Mechanic
Member's Gallery
Re: 6.0 Oil Leak at turbo
maybe the HPOP cover leaking. unless you can see it on the drain tube. there's a o-ring on both ends.
__________________
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, Warren's 175/30 injectors with upgraded spool valves, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. And I'm the mechanic
  #3
Old 05-10-2012, 04:44 AM
Monster758's Avatar
Monster758
Offline
Member's Gallery
STC fitting? I was having a similar problem. Didn't think much of it at first. Truck shut down 30 min outside of Vegas. 600 dollar tow service to 1000 dollar repair.
__________________
2005 F-250 Custom 4" TB exhaust, AFE Stage II, High Idle Mod, CCV Mod, 6 Inch Fabtech, 35/16 wide Dick Cepek tires
  #4
Old 05-10-2012, 12:04 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
STC fitting would create a internal oil leak.
Maybe pull a inner fender well then you can see the back of the engine better.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
  #5
Old 05-10-2012, 12:11 PM
stroke of luck's Avatar
stroke of luck
Offline
BRING DA AMBALAMPS
Member's Gallery
truck wont hot start if it was an stc fitting...
__________________
2005 CC FX4...compounds and everything else that goes with em.
  #6
Old 05-10-2012, 12:13 PM
stroke of luck
Offline
BRING DA AMBALAMPS
Member's Gallery
that's what I said over on psa too....give those a look
  #7
Old 05-10-2012, 12:17 PM
bgc
Offline
Member's Gallery
I mangled the lip of drain tube refitting the turbo causing a leak, quite oblivious it was dripping down the tube.
  #8
Old 05-10-2012, 11:47 PM
SaNnDnSurF's Avatar
SaNnDnSurF
Offline
Stock Sucks!
Member's Gallery
Thanks for the quick responses guys we replaced the oring again and all seems well now he said it looks like it didn't seat the first time. Fingers crossed lol
  #9
Old 05-11-2012, 02:18 AM
DeereMan83's Avatar
DeereMan83
Offline
Diesel Addict!!
Member's Gallery
dont feel bad. I did the same thing when I put my 03 turbo on.Ive got to where I have plenty of o-rings laying around!
__________________
05 F250-6.0 FX4,Zoodad,58V FICM,PHP FICM tune,EGRD,Studs,155/30's,S&B,CFM+ LM,ELC-1,4"MBRP/Silverline,Powermaxx,Gogo,Harley Grill, 08 gate-20"s-door panels,console,Edge CS,VT365 IH Dressing, Westin BG,Updated FX4,STC,GN hitch,Line-x,PMM Coolant filter with deere filters, NFAB 6-step
If its not a Deere, It must be a Puss!!
  #10
Old 06-24-2012, 12:35 PM
ksieckmann's Avatar
ksieckmann
Offline
Gambled and Lost 6.oh
Member's Gallery
Mine started leaking after putting 03 turbo on last night, going to pull it tonight and check o ring , that was my first guess too.
__________________
'05 CCSB FX4
Deleted, Studded, SCT w/ Vivian's Looney Wild, Warrens 190cc. DieselRX
Performance-Fueling.com
Human Verification
(View-All Members who have read this thread : 100
03F250 6.0, 06 f250 man, 06-6.0 stoker, 06kingranch37, 06regcab6.0, 06_WhiteBull, 1hardmoney, 2005stroker, 494doug, 501outlaw, 5150lariat, 93_444idi, afFORDable, amdriven2liv, bassrippin365, bennett, Bens98gt, bgc, bigvern64, Blacksmith01, boboznutz, brute_mt, charlez, chucky1313, CJFire, cm22, coltonsommar, Cory2537, cory99, Country Girl's F250, c_ratkovec, daywalker, Dcraig86, DeereMan83, eric97svt, F-250-Owner, FaSSt9602, fobar22, griffin6997, Hamstn, Harley Strokin', harveyev, Hobo-Stew, Iron, jake30310, jeff7825, Jingoist, jmsmith76, Joemahma, Jtbenfie, kkesler, ksieckmann, Ksop2001, ktmrydr686, mantis118, mastrkee, meandog06, Misn 1, mm2v2, Monster758, mours2, Mr & Mrs Stroker, Mr. Navistar, mrgeno, Msolem, muddynoll, nitrouskid2601, NJ2005X, Plumbnman, Polkville, POORBOY1964, pwrstrk6.0, range91, RAUD, RescueF250, rsmith7373, runs2rch, SaNnDnSurF, scooby, semmens21, Shaneo0918, shreyshah1120, skinny, SLOSIXOH, spoken0313, stoke17, stroke of luck, strokin350, TexasStroke01, The Gray Mule, Theestroker, toolmangary, turbotibbo, Vannelli, vindiesel2, vista461, Wangfu12, webb06, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
