Hey guys I am looking for a list of all the gaskets needed when doing headstuds and an egr delete. My buddies 2004 6.0 is going to be going under the knife and we just want to make sure we have everything we need before we start. Thanks for the help!
You'd be better off to just buy the whole gasket kit. Includes all gaskets,o rings,valve stem seals, intake gaskets, valve cover gaskets, exhaust manifold gaskets, turbo drain o rings, injector seal kit, oil cooler gaskets, and hpop gaskets. Also comes with black onyx head gaskets that you should NOT use. But put ford oem headgaskets on.
You'll need rocker box gaskets as well as all the above.
D
