What is the true definition of leveled for an excursion. Same measurment at top of front and back wheelwells. Think i got about 3 inches from my spring swap, wondering if 2 inch shackle on back of front springs would help?
GOT HER LEVELED TODAY. added a 2 in mini pack plus 11 inches cut out of the factor springs which made mini pack 3.25 inches. i think she looks just like i was planning when i bought her, no wonder my wife calls her my mistress
Front V code springs: Part #2C3Z-5310-HA
Rear B code springsart #3C3Z-5560-CA
30mm SD rear sway bar F81Z-5A772-AA
Min 9" wide rims, 18" for 33" tires 20" for 35" tires. Excursions need a stable base factory rims are to narrow.
To get the Ex to ride correctly, comfortable and corner flat these mods must be done.
Install:
V code SD springs front.
B code SD springs rear with spring mod.
Replace the stock rear sway bar with a 30mm SD truck bar (new or used).
Set of correctly valved Bilsteins.
Adjustable track bar.
just figured out how to move pictures out of my photbucket account, this is the mew stance. x codes? up front but could be v codes only got 2.5 inches of lift so i added a mini spring pack for custom diesel in tennessee thinking it was 2.7 inches but was only 2.0 so i added 1.25 inches by cutting out the middle of my old springs and adding it to the spring pack up front with new u bolts and procomp shocks, waiting on my dual bracket and another set of shocks for up front. i added a pmf 4.5 inch block in the back with new u bolts and procomp shocks. gonna look for a picture of my excursion when i bought it to post up.
