I've read alot where people use muriatic acid to clean cooling system for marine engine also it's all types of engines as well. I remember my dad owned a heating and air business and he would use it to clean coils on peoples inside unit . Question is how would it work on a powerstroke
It would take ALOT of flushing out. Marine engines are not a closed system. A few minutes of running and they have put a lot of water through. Your truck would take a lot of fillup and drain cycles. What little you may not get out of the marine engine will flush the next time you go to the lake. What is left in your truck is there for the next 100,000 miles. Others may feel differently, but I just don't think I would do it.
Since around 2001 -2002 a lot of boat motors went to closed system. Both my motors (496 HO's) are closed cooling with a water to coolant heat exchanger.
Use the Restore, I used it last year and worked great. Bad news it took 26 gallons of water to get all the bad stuff out.
I wouldn't do it either - nothing wrong w/ the chemicals made for the job (assuming you really need them). If you have no issues with cooling and your temp spread is OK (ECT vs EOT), you probably don't need ANY chemicals.
If you have a swimming pool Muriatic Acid is used to reduce the Ph level of the water. If you think M/A is bad for your truck's cooling system think about swimming in it (albeit diluted, but still).
I'll keep that in mind next time I plan on swimming in my degas bottle.
Please don't tell me you're drawing an equal comparison to a system plumbed almost 100% in plastic and designed to withstand chlorine with the cooling system on a vehicle.
Well I gave it some thought and basically muriatic acid is not going in my ford And I remember last year when finished up a coal fired power plant in Virginia the cleaned the entire system with a degreaser / citric acid mix. They said when they were done the tubes and piping would look new.
If you wanna do a good flush Fleetguard makes a great flush system. You can get it at any Cummins dealer/distributor. I've used it many times and its a great product
Remembered what the Fleetguard stuff is called. Its Fleetguard Restore. Couldnt think of the name when I posted but I've used it extensively and would definately recommend it.
Loon I'm heading your way I've been working 7 14s and I only have time to chat on here I hope this weekend I'll make it your way or if we get rained out this week
@ super dirty 06, there's Restore and Restore + . I used the restore when I flushed my system last year. I would recommend to anybody considering using Restore + to do some research, I mean a lot of research, as it breaks free a lot or metal flakes inside your engines cooling system which can/will clog your oil cooler. The restore is meant to break up the gelling of the gold crap.
Didnt know there was 2 different ones I just use what the parts dept hands me lmfao. Good lookin out. I defs still wouldnt let muratic acid touch my cooling sys. Maybe a quick dip for parts off the truck but that stuff cant be good 4 ur o rings n de-gas bottle and probably everything else it touches. Just my .02
