Does anybody know where I can get a set of banjo bolts? I bought and payed for some from dozers diesel on the 31st and still no word. Won't return a phone call or a email. I can't get a break. Does anyone know how to do business anymore?
Thanks, any response is better than none. 10 days is awhile to get back to someone. Appreciate you sending it though. Thanks everyone for your promptly help.
Just to make sure I am understanding things the Banjo bolts and blue spring are pretty much needed if you want your truck to run smoothly.
As far as install for the Banjo bolts they seem pretty straight forward but the blue spring is a PITHA. I know I am new here but I wasn't able to find a write up on the instalation of these items. Thanks in advance.
Its just the two bolts in front of each cyclinder head that are attached to the fuel lines and the fuel spring takes like 4.6 minutes...torx t27, two screws pop the cover remove spring and replace, put cover back on and done. You can do it!!
Dual altenators is why is havent done mine. Not looking forward to the PITA.
