6.0 EGR delete question - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 03-26-2012, 02:15 PM
Rdh605
Offline
Member's Gallery
I just purchased a 2005 6.0L 6 speed 4x4 F350 SWB. The guy told me the EGR had been deleted but I want to MAKE SURE it has. How can I visibly check this to know if I need to order a kit or not? I have dealt with 7.3 and 6.9 engines but this is my first 6.0.
Reply With Quote Quick reply to this message Go to the top
Old 03-26-2012, 04:30 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
Re: 6.0 EGR delete question
Look under the intake manifold on the right side and see if the cooler is still there, also see if EGR valve is still in the intake manifold.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
  #3
Old 03-26-2012, 04:32 PM
501outlaw
Offline
Member's Gallery
Depends on if they did a block off plate or a real delete look under the turbo on the left side under the intake and see if you see it
  #4
Old 03-26-2012, 04:35 PM
501outlaw
Offline
Member's Gallery
6.0 powerstrokregt cooler - Google Search
See the blue hose that's part of the egr
  #5
Old 03-26-2012, 04:36 PM
501outlaw
Offline
Member's Gallery
http://www.performanceboats.com/gall...a/500/0212.jpg
Sorry click on this link
  #6
ghohouston's Avatar
ghohouston
Offline
whistle tits
Member's Gallery
It will be a long square tube under the passenger side of the intake man. It will have a blue or orange connection to your oil cooler if its stock still. Maybe take a pic and post it up on here? Or email it to ghohouston@hotmail.com
__________________
1997 F350 SRW CCLB 7.3 ZF5 4x4, 6637, 5" exhaust, ebpv deleted, Gearhead tuned, complete super duty e fuel setup. Hydroboosted, Lightning seats
  #7
Old 03-28-2012, 11:10 AM
Rdh605
Offline
Member's Gallery
It still has the EGR in it. Now to delete or try to keep it clean and working. How difficult is the deletion to do? I have heard an SCT or Gryphon programmer can solve the problem without deleting the EGR, any thoughts on that?
  #8
Old 03-28-2012, 01:11 PM
ghohouston's Avatar
ghohouston
Offline
whistle tits
Member's Gallery
Physically the delete can be done in a few hours if you know what youre doing
  #9
Old 03-28-2012, 01:59 PM
Term3's Avatar
Term3
Offline
'05 Excursion
Member's Gallery
A full delete is the best way to go if your state allows it. Tuners will keep the EGR valve closed but it doesn't protect you if your cooler springs a leak. Even if you remove the EGR valve leave it plugged in for proper fan clutch operation.
http://www.thedieselstop.com/forums/f21/egr-delete-will-fan-work-not-275000/
__________________
  #10
Old 03-28-2012, 02:11 PM
501outlaw
Offline
Member's Gallery
Just do a real delete if that cooler gets a leak you'll have more problems to worry about
Human Verification
(View-All Members who have read this thread : 299
01strokin, 02bestroked, 03Excursion, 03fathead6.0, 04 f350, 04La4iat, 05_HD, 06F250Kingrach, 06f350stroker, 06pwrstrk, 076.0, 07plower, 100%lemonhead, 1000klr, 1bad306, 2003ford, 2005stroker, 2006powerleaker, 2kool, 350blk6.0, 3sixjoshua, 444CuiOBS, 501outlaw, 50gstroked, 6.0>5.9, 6.0power, 6.0TJ, 66IH1206, 86F250, 89gearhead, 96Powerstrokin, 97blackbetty, aboydf04, Agjake11, ajennings, ajfetterman, alalhunter, almostfinished, arcticstroker05, Atc-Eric, Austinfqt, avm112, Backwoods Electric, Badger F350, baggedbug, balderthanu, BAMP, Bang'em Mangum, bassanglerbob, Bbaker86, BDS, Bensmeding, bgc, big bubba, Bigdog, BigMike, bigstrap3, bigvern64, billguns1, birddog55, bismic1, bknudtsen, BlackPearl03, Bleed Blue, Bogath, boilermaker123, bosssuperduty, Br2200, BranodizingKailua, Brotherbob, brute_mt, bubba33003, bubbaed, buddy357, buggut, Bustedknuckles, b_b, cchoptank11, cdraggin, chaz1marine, chrisdavis_16, chunkdunker, CliffordOnRoids, CLVTCH, Codydiesel, colekym, coolvette, crash214256, crossroads diesel, CSaley, CSheriff, cummins kid, d.warner23, Dairy6.0Land, daves02, David Craft, daywalker, Dbook, deerehauler, Devilstang93, DevjWilliams, DieselDan73, diggersps, dits145, dukedrummer89, Duracrap, Dustin F2504x4, Edward.crossett, F-117HWK, F-250-Owner, F350R, FarmRig, fatzack55, fchis, ferociousfish, fordboy11, fordfanatic69, fordfreak84, Fordhorseplay, FORDMAN345, fordota, fordtch8, Fudge0514, garyv350, ghohouston, Grey6.0, HankyD, hanleyj, harleyf250, HeadHunter, highpockets, hill_billiez, hi_po_heads, Hobo-Stew, hoosier6.0, hystrung2xpi, Idahoser, ImShot, imthemedic, indiana lineman, irish4, ittech729, J HO 22, jamcconnell2, jarrod6.0L, JBHRacing, jg6.0, jhhouse, jimhall_az, Jomull55, Joshbaker, jumper, jurquhart, justind, jweber6.0L, KAWGRN, KD05PSD, kingranch1, KingRanchSick.0, knothead, koda22, ksieckmann, LAXipad, LBF, leechapple22, LOSTCAUSEPOWERSTROKE, lubeowner, Mad Dart, mantis118, maps, markgyver, mastrkee, maxsd250, mcnabb, MDpowerstroke, meflamout, metalnova, Michigan XLT F350, Michipicoten_SuperDuty, middlemanjw, Mikeh1725, MikeHawk509, mkelly, Monst3r02110, Monster758, MPTonyT, mra4x4, mryanc, muddynoll, mx185sw, navistar45, NAZTY 4X4, New6.0PSOwner, NH OIL BURNER, nickPSD, NitroJW, Nodak9, North Pro diesel, NoSlow6.0, nrook, Nutz, o4ep3civ, Onebadbia, onefaststang, pappy42, pbuxton11, plumber dave, pmpislander, Polkville, PoohBear, power-smokn, powerstroke44241, powerstroke6.4, powerstrokedkid87, PowerstrokeMudder82, pwrstrk6.0, Quadracer, randys2004, range91, Rbloodhound, Rdh605, reason1941, Rescue48, rgerman65, rgullett83, rlm2198, roddy, rollingcoal69, romad99, runs2rch, RY86, Sage22777, Schwad65, sdanko99, Sean_04Ford, SFC Beaulieu, Shaffer6.0, shreyshah1120, silverbullet62, skeetreecetw, Skpph, SLOSIXOH, sly1types, soapy, Southern.Charmer, squad2man, SRQ Stroker, ssdeuce, Steelmonkey, StillStrokin 7.3, stoke17, straightaxle, stroked06, Stumppy, Styler_Colfax, superdooty89, superstroke80, svorob, T SCHMIDT, t4050nh, tankersrule, The Butcher, The Gray Mule, the06wildebeast, tl1000r, Tom's 2006 F250, tomfegan, toolmangary, towin stroker, tuhy, Turbodiesel6.0, TVMC, TWJ, uga33, unimog1300, vegasff13, Vin6.0, vista461, wanabebig, wargle, Wartboy, Wazincow, webb06, wetley, Wheelhop, Whiskey River, Whstln, yamaman, Ycanti, yz85rider2002, z28fred, Zane-03 King Ranch, ZBrooks, ZCMiller, zdot500, Zmann, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
