How many quarts of oil 6.0? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 02-22-2012, 07:40 PM
mra4x4's Avatar
mra4x4
Offline
Member's Gallery
Iam new to the truck and doing the first oil change I have a 2005 6.0 and was wondering how many quarts of engine oil it takes?thanks!
Reply With Quote Quick reply to this message Go to the top
Old 02-22-2012, 08:30 PM
slipknot05
Offline
Member's Gallery
Re: How many quarts of oil 6.0?
That would be 15 quarts.
  #3
Old 02-22-2012, 08:39 PM
2 Stroker
Offline
Member's Gallery
As stated 15qts get a 5w40 Syn oil and use Ford or Racor filters only you can get them at Walmart FL-2016 and Shell Rotella T6 5W-40 Full Synthetic or Mobil 1 Turbo Diesel Truck 5W-40 is a fully synthetic your injectors will like it will cut down on stiction and cokeing a big problem with the 6.0 and the max is 5000 miles because of the shear of the oil by the injectors.
2 stroker
__________________
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
  #4
Old 02-22-2012, 08:41 PM
amdriven2liv's Avatar
amdriven2liv
Offline
Member's Gallery
Check your oil level after 14.5 quarts and see where you stand. I haven't gotten 15 in mine yet.
__________________
Walk to Defeat ALS We Walk for Kay
"I'm hitting easy street on mud tires"
  #5
Old 02-22-2012, 08:50 PM
amdriven2liv
Offline
Member's Gallery
Also, I leave my oil level a little lower than most. (just a little above halfway) So I can catch if ever an injector starts to leak and fuel starts getting into my oil. Rise in oil level isn't a good thing.
Fuel in Oil - Ford Truck Enthusiasts Forums
(from the spread sheets)
  #6
Old 02-22-2012, 08:53 PM
new2deisel's Avatar
new2deisel
Offline
Member's Gallery
a lot
  #7
Old 02-23-2012, 04:04 AM
bismic1
Offline
Member's Gallery
The full charge is 18 quarts (on a dry engine).
To get to the full mark when changing oil can take you 13.5 qts, 14 qts, 14.5 qts, or 15 qts. Who knows why the variability, but filling past the full mark doesn't make any sense to me. I like your reasoning amdriven2liv.
__________________
Mark
  #8
Old 02-23-2012, 04:55 AM
mra4x4's Avatar
mra4x4
Offline
Member's Gallery
Well I did the change and got 16 quarts in and that's right in the middle of the dip stick reading
  #9
Old 02-23-2012, 06:09 AM
joe_r_dog
Offline
Member's Gallery
use synthetic?
  #10
Old 02-23-2012, 06:32 AM
Ian123's Avatar
Ian123
Offline
Member's Gallery
I put 14 in my last change and it overfilled...weird how everyone's is different
__________________
2007 F-250 CCLB Lariat FX4 6.0L
Originally Posted by fuekear View Post
I just blow my heads off the block once a year. Keeps nice clean antifreeze in it, although not that cost effective it sure is fun.
Human Verification
(View-All Members who have read this thread : 277
01strokin, 02POWERSTROKE7.3, 03KingRanchCC, 04 f350, 04MT, 06 f250 man, 0660stroker, 06Jtbear, 08strokin, 125py, 1bad306, 2 stroked, 2 Stroker, 2005F350, 2005stroker, 2006powerleaker, 24Vford, 2ndHandSmoke, 350blk6.0, 494doug, 4Scott4, 50gstroked, 5150lariat, 6.0.downlow, 6speedSD, 73smoker, 95gasser, 97powerstrokecclb, 98stratusryder, 99whitePSD, airfish2011, alalhunter, amdriven2liv, anastosmak, Backwoods Electric, baggedbug, BBowden73, bennyboy, bhanger24, bhc99, Big Papa 03 dually, bigstrap3, billguns1, biostroke1, bismic1, black2door, blake14, BnBRacing, bootcamp, brc51o72, Bronco_Jer, Brut4s, BTJ, Bustedflush, BVP, Cam45, capcalvin, carrj66, cgp182, charlez, Chompper, clp13294, Cobra 19 & 54, cobrabc1993, CodyGraham, coolvette, cporda, CSheriff, cshsrh, Csulli250, cumminskiller69, curt 2006, D HD, Dal, daywalker, Dieselgeek, diggersps, Dirty outlaw, dirtydieselsixoh, Diverhardhat, doomee78, Doug800, drh4250, dwhite, DZLAL, ed3196499, elbow_grease, Euroman, excummins, ExToy, ExtremeFord4x4, F350F351, farmer09, farmer8, fdny2536, fireanchrome, firebolt12r, firehouse63, FirstSixOh, fletchdogger, Flexxx, FlossyB, Force2354, fordboy11, fordfan30, Fox'sFord, freeride808, gasman1962, Gbarrera, Geereed, ghohouston, GO DIESEL, Handyhiker, Harley Strokin', HarleySuperDutyF350, HeavyAssault, hill_billiez, Honda30, hoosier6.0, Hotroddave, huck2080, hwc, hystrung2xpi, Ian123, Ignorant1, indiana lineman, internationalpsd, ITAcelica, ittech729, JamieCiambelli, JBASS30, JD F350, jdc753, jdpolzin, jeff7825, jeremyshanemoore, jg6.0, jg7544, jhenrichs77, jimbo4au3, jl250sd, jobsi, joe_r_dog, john gerbas, Jomull55, Jpotts24, jven6.0, jweber6.0L, keblmo, king dinger, kp38, Krisco, KT Performance, kyleholmes33, leechapple22, lifted03, m j, Mach5Customs, majek5, marshall99, mastrkee, mcdmn717, Mdub707, meanfarmer, medicman88, Mhatlen, Michipicoten_SuperDuty, Mike T, Mikeysford, mjcolemn, mooch91, Most Hated, mours2, Mparsons388, mra4x4, mryanc, Mud digger, muddynoll, mx185sw, necks00, new2deisel, NH OIL BURNER, nickPSD, noe2big, nrook, OBSPowerjoke, oconnors17, One-eyed-dog, orchard6, parne, paultfh, pbuxton11, peg25, pizza pig, pjwoolw, platinum7.3edition, plumber dave, PoohBear, poppinjohnny, Powersmokesd, powerstroke0786, powerstroke095, powerstroke927, Powerstroker09, Proffitt, PSDNUTS, PuFFeR, R50, ramblunman, Realdealoo8, reason1941, Red046.0, redhors66, reis1995, renegade, RescueF250, RHCDIESEL, Riddleman2002, rkesar, rollingthunder, romad99, Roush4_6, ruizhernandeztrust, SAYIWONT, SDER1, sfoltz, sg465, SgtCoalRollingChicken, Skpph, Slgolden0, slickwillie, slipknot05, slyfly76, Smokediver3, Smokin Stroker, Sniper32, socoman1988, SonicDiesel99, sparkey308, sradams21, steel, Stevenmc08, striderop, stroke of luck, Stroke22, StrokerSmoker01, Strokin2004, superdooty89, tankersrule, TCNashville, teena, The Gray Mule, TheGoose, TimmyNiewald11, tinman565, TinyF350, Tj12, tmanrose2007, toverbey21, Turd-250, unclemark, unimog1300, vegasff13, Vin6.0, Vmette72, WCH_diesel, Weatherlite, wetnsloppy4x, white00strokerks, whiteford350, wkrpinnick, wkysanta, wynndaddy, wyoradcat, xsfpns, yaitsme, z0650
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
