Weathertech Matts
AMP Research Powerstep
BMF Novakane Death Metal 20x9
Toyo Open Country MT 275/65/20R
4 extra Ford TPMS sensors
Firestone Ride-Rite Air-Bags
AIR LIFT 72000 Wireless Air Leveling Compressor
Ford Factory Rear Sway Bar
Diversi-Tech Hitch DT-ALBM6625
Leer 100XQ Topper
Keyless Remote for Leer 100XQ
Coastaltech Lockpick
Pace Edwards Powergate
Recon Smoked LED Mirror Lenses
Recon Smoked LED Cab Lights
Recon Smoked LED Tail Lights
Morimoto mini D2S Bi-Xenon projectors / Gatling gun shrouds / 55W 4300K Bulbs / Smoked
Door Seal Mod
Edge 83830 CTS Insight Monitor
Recon LED Backup Light Bulbs
Looks good
How do you like the projectors? Any better pics and any shots of them on?
Just an idea- I'd throw on some KR bumpers and maybe a PTM grille surround and your truck will look even better imo. Not to make it a KR clone, but it would tie everything together well.
Thanks for the pics! They do look good, and after some adjustment I'm sure they'll be right where you want them.
It's about 100x better than the factory lights I'm running now. I'm used to doing HID bulbs, but I may go this way this time around.
I had JB @ Black Flames Customs (AKA Performance Auto Solutions) modify my factory housings, he installed the Retrofit Solutions kit with Morimoto mini D2S Bi-Xenon projectors / black gatling gun shrouds / 55W 4300K bulbs.
He smoked orange side lens and blackened the inside of the housings leaving the front lens clear so I would be legal in WI
Here are a few of the pics of my lights that he emailed me during the conversion.
I guess I should mention we had a heck of a time getting them to work, we tried two different harnesses and one new ballast but could only get one side to work and the other side was just the low beam only.
I ended up using a couple small individual harnesses that Retro sent, they do not have the bigger ballasts nor do they connect directly to the battery. I would assume that this is not the preferred method and that they will be even brighter when we get the normal harness & ballast combo working.
I will talk to Todd @ Retro next week again and see where to go from here.
Both JB at Black Flame and the guys at Retro bent over backwards to get on the road both over-nighting stuff for us to try. I have no doubt we will get it sorted out.
Truck looks awsome!! Wanting to do the same sort of thing with my factory housing with basically painting the whole headlight unit, does it lose any reflection or brightness in your opinion? Is the black a flat black? and did he use the spray tint for the reflectors? Sorry for all the questions just really like the way it looks!
He did spray tint the reflectors and put a matte black on the inside of the housings. With the projectors they really don't use the reflection as they sit a few inches forward of the housing.
So in your opinion if I was to do the same thing with factory housing with hids would it affect the light pattern, I have 6500k HIDS but not a fan off the with the chrome still on the inside. Yours by far look the best I have seen on the 2011-2012 trucks!
Have I don't know I guess I have to sets so trial by error, thanks for all your info helps alot! I will post some pics with all the new add ons ptm bumpers grille and headlights!
