i am going to be running 40's dd I'm looking for a hydro assist kit that will do a better pump/gear and if i have to modify hydroboost to flow with them i will..
I have redneckoffroads kit. I sent them my steering box and the tapped it and shipped me everything back I had to weld on the tabs to mount the ram tho that's not really how I wanted to do it but it works. Also make sure no matter how good you think your stock pump it replace it!
I took the pump apart and took the piston out and drilled it one size bigger it ended up being a 1/8 bit I also stretched the spring lest than a 1/4 inch for a little more pressure.
It removes the bottle neck in the hydro boost. The bottle neck is responsible for steering loss during hard braking. It also removes back pressure on the pump allowing it flow freely.
.Pirate4x4.Com - Extreme Four Wheel Drive Not sure what pump is on the newer SD, but this will give you a general idea.. Im looking to do this to my jeep(jeep body on ford running gear) to help turning the 38.5 boggers in the woods. I hear its suppose to be real nice..
