As many of you know, I recently received my Elite 71mm low pressure turbo. Well it's already on the truck and I have close to 200 miles on the truck testing the new setup. Yesterday, dieseljosh07, uga33, 4tonGT40, and myself got together to tackle the job. I was more or less there for moral support and supervision, but I did help a little. I would like to thank dieseljosh07 for his awesome skills as a diesel tech. If it wasn't for him, I wouldn't have been able to get this done so quick. Thanks buddy! uga33 knowing the front end of my truck like the back of his hand was good because I needed to get my Icon TEI out to ship out tomorrow. And finally, 4tonGT40's ridiculous fab skills were used as well. Those damn heat shields!!! :hehe:
I would also like to thank Elite Diesel Engineering for providing me with an awesome turbo. JD was a lot of help and was great to deal with, keeping me updated on the turbo. Talk about some great customer service!
Alright, on to the review. All I can really say at this point is.....WOW! I am so pleased with my new setup. There is nothing that I have found that I dislike about the new setup. We did run into some issues with the POS Diamond Eye downpipe that is on the truck, but powerstroker67 is taking care of that little problem this coming week by sending me one of his ceramic coated downpipes. The turbo spools quick, makes some serious boost, and sounds wicked. I didn't think it would have the whistle that it does under load, so that has been a huge bonus. Always nice to get a little extra than you expected. With my current setup (dynoed 594 on Dunbar's last March), I can definitely see 30-40 HP being gained with the 310 tune. I don't want to say my truck will make 630 HP, but seat of the pants it feels so much stronger than before.
Now to the data logs....that I unfortunately forgot to monitor throttle position percentage, so I can't really say how hard I was in it. It was 54* and very low humidity when I performed these logs. Perfect weather!
Data Log 1 - acceleration from 34-72 MPH at what I would consider between 1/4 and 1/2 throttle.
Max EGT - 1,072*
Max rail pressure held - 25,400 psi
Max boost - 53.7 psi
Max back pressure at max boost - 52 psi
Max EGT at max boost - 1,066*
Max back pressure - 56 psi
Boost at max back pressure - 30.1 psi
RPM at max back pressure - 2300 RPM
MPH at max back pressure - 38 MPH
Rail pressure at max back pressure - 21,950 psi
EGT's at max back pressure - 756*
Data log 2 - acceleration from 68-85 MPH at around 3/4 throttle
Max EGT - 1,128.6*
Max rail pressure held - 25,600 psi
Max boost - 54.6 psi
Max back pressure at max boost - 60 psi
Max EGT at max boost - 1,047.6*
Max back pressure - 60 psi
Boost at max back pressure - 53-54 psi
RPM at max back pressure - 2170-2240 RPM
MPH at max back pressure - 78 MPH
Rail pressure at max back pressure - 24,600 psi
EGT's at max back pressure - 1009-1050*
Data log 3 - acceleration from 65-92 MPH with the pedal to the floor
Max EGT - 1217.1*
Max rail pressure held - 24,900 psi
Max boost - 55.5 psi
Max back pressure at max boost - 59 psi
Max EGT at max boost - 1,068*
Max back pressure - 65 psi
Boost at max back pressure - 53 psi
RPM at max back pressure - 2580 RPM
MPH at max back pressure - 91 MPH
Rail pressure at max back pressure - 24,700 psi
EGT's at max back pressure - 1208*
If there is anything anyone else would like to know, just ask. I can look it up on the data logs I took if I have that particular PID logged. The most boost I have seen was 56 psi and the most back pressure I have seen was 66 psi. This was pushing it as hard as I could from a rolling 70 MPH. Hopefully this review helps others on the fence about a turbo setup and also helps those looking for hard data using a big low pressure turbo matched with the stock VGT. I will post some pictures in a bit when I get them uploaded to my computer.
Thanks,
Jeff@Spartan
Max EGT - 1,072*
Max EGT - 1,128.6*
Max EGT - 1217.1*
Thanks,
Jeff@Spartan
