I was wondering if anyone has ever cut and threaded the factory trac bar? Using a adjustable sleeve for adjustment exactly the same as the zone trac bar and many other companies do.
If so, what size die did you use? I know there will be a RH/LH thread on either end for the adjustable sleeve to work. you can get adjsutable sleeves at any parts house.
so if anyone has done this and can remember any sizes for the die's i need to use.
If I can't figure out what size to get. I plan on installing the leveling kit with the trac bar unbolted. measure the new center bolt to center bolt lenth and cut and sleeve the factory trac bar.
any input would be appreciated, thanks
