How long to purge air??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 01-21-2012, 07:06 PM
deathwishracer's Avatar
deathwishracer
Offline
Member's Gallery
So I have replaced injectors, stc fitting, standpipes, dummy plugs, ipr, and icp sensor, and batteries. I had some issues throughout this repair, but finally she fired. Starts fine, hot or cold. Still seems to have a slight shuttter at part throttle. Could it still have air after 20 mile test drive? Also, still set light one time for icp circuit low. Don't have the scanner right now to monitor pressure during drive. Could air be causing this? 2006 6.0, stock.
__________________
00 drw,auto,6.0 cooler,tymar,overboost annihilator,4 inch exhaust,ITP intank mod,GT38R,DPTuner F5(60tow,80econo,140 extreme),stage 2's,diy fuel system rr,adrenaline,airbags,Katzkins leather seats,A-pillar gauges,05' front end,HID headlights,cowl induction hood,all lights are l.e.d., 24 inch alcoas
Reply With Quote Quick reply to this message Go to the top
Old 01-21-2012, 11:38 PM
6.0lover/hater
Offline
Member's Gallery
Re: How long to purge air???
whats the code number? and when you test drove it did you drive it hard or just put around?
  #3
Old 01-22-2012, 12:07 AM
bismic1
Offline
Member's Gallery
you should do a series of 3-4 WOT runs (after the truck has warmed up) to fully purge the air out.
__________________
Mark
  #4
Old 01-22-2012, 04:22 AM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Send a message via AIM to CTC DEEZUL
ford spec is 12 wot blasts under load..... i just drive the truck for 30 minutes, some wot blasts to 70 mph than cruising...
__________________
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
  #5
Old 01-22-2012, 04:44 AM
bismic1
Offline
Member's Gallery
Couldn't recall the number!!! Was way off - thanks CTC
  #6
Old 01-22-2012, 06:19 PM
deathwishracer
Offline
Member's Gallery
Yeah, didn't have that much time, or wot runs, so maybe still air. Would that cause a low icp circuit light?
  #7
Old 01-27-2012, 11:14 PM
deathwishracer
Offline
Member's Gallery
Got about 250 miles on truck after all the repairs. Still shutters at part throttle, check engine light is on. I will try to get scanner, and take readings on a test drive. Without the info from test drive, does anyone have a shot in the dark about where to look first?
  #8
Old 01-28-2012, 02:09 AM
bismic1
Offline
Member's Gallery
We really would need to see the ICP readings and the corresponding IPR duty cycle readings.
Human Verification
(View-All Members who have read this thread : 71
$and$hark, 04krpsd, 06 f250 man, 1000klr, 6.0lover/hater, 6spdcr, 97F250 HD, acplowboy84, Ajdelhomme, alalhunter, amxgilligan, awesomewrangler, Bad Habit, benjiblaze, bismic1, chevyboy123, chrome04strokin, Codydiesel, CTC DEEZUL, darsey715, dave0642, deathwishracer, dieselmac, E99Superduty, eleventhtruck, FamExc, fast1000busa, fordfan30, halhiggins, Harley Strokin', hill_billiez, HiVoltage, Honda30, hystrung2xpi, Ignorant1, indiana lineman, ittech729, IWANAFAST6.oh, jimhall_az, joe_r_dog, jseasor, jth4570, jzamluk, kyle43335, medicman88, Mustangl3, ndnJedi, nrook, pizza pig, range91, Realdealoo8, reo12, robinson970, rschwarzwalder, runs2rch, SaNnDnSurF, shadow6.0, sly1types, snagalittle, Sniper32, Stonepusher, superdooty89, Tommyboy, Turbodiesel6.0, turbotom1052, villestrip, wbwright, Zmann
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
