if i level my f250 4x4 and install a 2.5" leveling/lift. how much longer does it need to be? If I remember the factory trac bar is 29.5" center to center.
I was either going to cut and thread a adjustable sleeve similar to the factory drag link adjustable sleeve. that would be the best way to fine tune the front axle centered under the truck.
But What I can do without searching for parts is cut it and sleeve it to some where around 31"s.
can anyone with a adjustable trac bar measure center bolt hole to center bolt hole to give me a idea what to make this one.
