My neighbor has a 05 six ohh and when it sit's for a while it runs rought then clears out .what would be causing this ? i was thinking fuel filters /injectors but whant to be sure though.
thanks in advance
-steve-
sounds like a bad muffler bearing. when they get a little dry they tend to make some noise and cause some unwanted back pressure, and once the oil from the ccv lubes it up it smooths out.
thanks in advance
-steve-
Unless something is leaking or throwing a code dont worry about it. Every 6.0 I have seen runs a little ruff on a cold start up incuding mine. But you could also cheak the flux capsitor or the canutin valve.ointlaugh:
107.5K members
