Hi. I just hooked up a viper 2-way remote starter and added power door locks with keyless entry/an alarm/and turbo timer. Everything went very smooth and there wasn't any problems except for the alarm doesn't wait until the doors are closed to arm the alarm so I can't use the dome light as a door trigger. I traced the ground wires from the drivers side door switches and everything works as it should but the passenger door switch wires show ground at all times when the door is open and closed. I don't have the classic problem of the dome light staying on and everything works as it should when the passenger door is opened and closed (dome light turns on and turns off at the right times). What I'm trying to say is, does the passenger door switch work differently than the drivers door switch or am I just completely missing something. I have the alarm trigger hooked up to the return wire for the door switches, so when the alarm see's ground it goes off, I tried hooking the passenger side up in the same manner but it always sees ground (I tried both wires). Thanks for any help!
Jeff
Jeff
