After taking a look at some of the kits I cant seem to justify the $ to buy the whole kit. A lot of people have talked about just taking a piece of heater hose and running it down to the frame.
My only problem is when I go into the city I do not want the "trucks on fire look"
I have one of these small jaz overflow tanks. I was going to run a piece of heater hose down the fire wall to the frame and run the heater hose into a barbed fitting that would be taped into the side of the JAZ overflow tank. Would anyone see any problem with it doing that? I would run the tank so it could catch the oil plus not have the "trucks on fire look"
my question is that would there be any problems with running the hose into a canister and if I do run a hose down into the catch can do I need to put a breather on the top of the catch can so it does not build pressure up inside the canister? Also how often would I have to empty as I do not have any idea how much oil would buid up inside over a period of time.
I tried to search but all i found where people running heater hose down. Any help would be appreciated . Ive attached a picture of the canister I plan on using and I would just tap into it to (to connect the heater hose to & also if I had to tap a port to add a breather onto it)
sn:
sn:
