If you whant billet buy the GTX4202R.. I am not shure if you can buy JUST the wheel,, I think they are a little differnt in size..
Far what you would like to do.. Go with easer the 1.01 Exhaust housing. For the biggest you would whant to go would be the 1.15. BUT that could tend to be a little laggy.
You would want to put a waste gate in the mix to. nomatter what housing you go with..
i will but the hardest part is making a parts pile that just sits there when you want to rip old pieces off the truck and put the goodies on! my build should be done by january... just in time to sit in the garage. heres the plan, i already have bts building my trans but the turn around is three weeks plus shipping time, got the headers, mount, oil lines and turbo headed here in mid november, srp1 replacing adr (up for sale soon), vs, pr, hs (yet to buy), rear diff, hpop guage, waste gate, spearco ic (6.0 ic up for sale soon), and already have a vendor who is getting me the injectors.
one thing i need to address is the turbo outlet pipe for the 4202r and the manifold intake y. know where to get these?
like i said, parts pile lol.
So are you guys having luck with your GT4294R's lasting? I put one on a CR Cummins with some small 90hp tips and it was trashed in one month? Truck dynoed at 620hp with 52lbs of boost. It worked great....Just didn't last.
Maybe just a DUD charger from the get go...
Although...the S400 that replaced it runs way cooler, dynos ~same HP, @ less boost, costs 1200 less, and has been on for a year.
Sorry to highjack the thread....just giving a different opinion.
The GT4294Rs are a good turbo.. just not ment for that kind of boost. at 52 psi you had it out of the map and the turbo was spinning faster then it should have been.. that would cause them to go to pieces..
Over 50!!! LOL LOL LOL BUT they will and do go bad at this range. So most guys put a waste gate on them to keep drive pressure down. AND boost down..
AND it all depends on the Exhaust housing you have on the turbo to. Get on Garretts sight and see what the compressure map shows for a pressure ratio. 50 PSI is spinning the tubo WAY to fast and all you are doing is over heating the air doing that!!!!
good news is i just found out the billet wheel that is in the turbo should outflow the gtx4202r!
