I personally did not notice any difference after going to mine. At first, it seemed make a difference but I'm sure that was just my mind making me thing that after spending the $$ on it. If your planning on installing a boost gauge, then that is a good spot.
I plan on running a boost guage, but I was going to use the map line "t". Is this a more accurage place to run it from?
I am not sure if the AIH delete will make all that much difference, but i took my ic pipes off and cleaned them all up and that thing looks like it takes up the whole tube. So it will have to go.
I,m just gonna drill it out and tap it for a fiting. And yes it does take up quite a bit of the pipe, I don,t know if it make a huge diference, but I think it would help some.
I just used a 22m plug purchased from the local fastener shop. Drilled & tapped a fitting into it for my boost line. You can buy one like that too.
