i installed a set of faux 05' style harley headlights on my 99' today. they look great, but when i put my lights on tonight the low beams seemed really dull. even the high beam isn't very bright. also the blue high beam light on my dash is on when the lights are on low beam, its dim but its on. it goes to full bright when i switch to high beams. any thoughts on this ? thanks, jerry,
I would suggest checking your grounds... I can't remember where exactly where they are.. I ended buying a harness from LMC that uses only the battery power to power the lights.
i thought it to be strange that the wires could be spliced in without specifically matching. in other words the three wires coming off the new plug were all the same color.
I like the 05's way better. The brite box is used to run your High Beams and the Fog lights at the same time. Since I needed the conversion harness to go from 9007's - 9008/H13's I just bought the whole thing, brite box w/ conversion harness.
