have coolant spraying outta a round cap with two bolts and tabs for the bolts near egr cooler delete was installed if i take that cap off is there a o ring i can replace under there?
when i went in to ford to get mine they didnt offer the two seals at that dealership but they had the whole new aluminum cap with the o rings i needed so i broke down and did that. i cant remember what its called i just told them it sits on top of the oil cooler and the egr cooler is in line with it they should be able to find it!
Inner O-ring for outlet port - 3C3Z-9N693-FA (International: 1846975C1)
Outer O-ring for outlet port - 3C3Z-9N693-EA (International: 1846977C1)
