Hello, i just got a 4 Inch lift from one of my friends. It consists of 4" front springs and Rear Springs with F350 rear block. I know i need new Shocks and U-Bolts. My question is,is the drop pitman arm, sway bar links and whatever else comes with a kit really needed, If so where would i get them? Also, i was thinking 5100 Bilstiens for shocks, any suggestions where to buy them?
you can get the pitman arm on ebay for around 75 from many name brandand sway bar links just move the stock one like the insallations say or you can find extended ones on ebay or try venders on the site
Okay, thanks raptor. And would i need a adjustable track bar, or drop bracket also? I been reading and I dont wanna spend much more money then i need to, but wanna do it right.
I would definitely do the drop pitman arm and track bar drop bracket to keep the drag link and track bar parallel with each other. how bad is the ball joint angle on the drag link with out the drop arm and drop bracket. Are the two close to parallel?
okay thanks iam swapping lifts with my buddy i have a leveling kit on mine and iam getting his lift which is a 4in lift what all do i need of his truck so that none of those problems occur.
